NVMe-oF over ROCEv1 possible?
mattaw
Wed Mar 03, 2021 1:37 am
Can the StarWind iSCSI Accelerator work with the older ROCEv1 Connectx-3 implementation? (Note: Note Connectx-3 Pro which supports ROCEv2). I am debating whether I need to upgrade to Connectx-3 Pro or better.
[Maybe this should be an additional question, but does the NVMe-oF initiator require Windows 10 Pro for Workstations as a minimum?]
Dr Matthew Swabey
Wed Mar 03, 2021 8:42 am
Welcome to StarWind forum. StarWind iSCSI accelerator load-balances iSCSI sessions (you will need to reconnect those), meaning that it will not utilize ROCE capabilities.
Cheers,
mattaw
Wed Mar 03, 2021 7:31 pm
I am so sorry, yaroslav, that I made a mistake in my previous post and took up your time. I was trying to ask about your NVMe-oF initiator, NOT your iSCSI Accelerator.
So my two questions are:
  1. Can the NVMe-oF initiator work with the older Connectx-3 ROCEv1
  2. Does the NVMe-oF require the use of Windows 10 Pro for Workstations or might it work with Windows 10 Pro (Pro Workstation needed to use SMB Direct w. RDMA)
Thu Mar 04, 2021 12:19 pm
RoCE V1 is still fine.
NVMe-oF Initiator works with Windows 10.
mattaw
Thu Mar 04, 2021 2:24 pm
I really appreciate the time, thank you yaroslav.
Thu Mar 04, 2021 2:44 pm
You are always welcome :) contact us if assistance is required.
mattaw
Fri Mar 05, 2021 5:20 am
After messing about with the undocumented ROCE protocols on the old Connectx-3 EN card, using ROCE V 1.25 on windows (?!? only mentioned occasionally in some Mellanox docs) I was able to get nd_rping / rping running between linux and windows.
I was then able to use Starwind rperf to run RDMA tests which passed.
I was then able to configure and setup a NVMe-oF share of a ZFS zvol on linux -> windows. Performance is out of this world vs. iSCSI. Max read and writes on iSCSI were about 1.9GB/s read and 900MB/s write using ATTO. They are now 2.5GB/s R and W. Not only that but the 4k r/w performance increased by 10x!
Incredible performance. I am going to write a short blog post on it with some benchmarks as soon as I stablize the setup properly between reboots.
Fri Mar 05, 2021 8:01 am
Awesome! Thanks for sharing your experience.
Wed Jan 12, 2022 12:50 pm
Small update here. StarWind NMVe-oF Initiator does not work over ROCEv1.
ichundes
Tue Nov 12, 2024 3:53 pm
FWIW the initiator works fine for me with ROCEv1 on ConnectX-3 (Non-Pro) cards between a Windows initiator and Ubuntu 24.04 target.
Tue Nov 12, 2024 4:23 pm
Many thanks for testing and welcome to StarWind Forum.
vmware
Wed Mar 12, 2025 1:56 am
Hello, have you written the detailed configuration information for some experience
Wed Mar 12, 2025 6:31 am
I'd suggest not to use ROCE v1 and Mellanox ConnectX3 in general.
