Safe emergency shutdown?
wallewek
Wed Feb 24, 2021 8:58 pm
Recently I needed to do an emergency shutdown of our cluster (power failure, running on UPS), and I did it by simply using the Windows server shutdown procedure.
When I started the servers later, StarWind had to do a full sync. I know that there is a recommended procedure of stopping the StarWind services first, which should make a full sync unnecessary, but I didn't have time to go hunting for that.
So here's my question: Isn't there some way to automate a safe StarWind VSAN shutdown so that, if necessary, host servers can handle this automatically? It would seem to me it should be possible to have a shutdown batch script or something. I looked, but maybe I missed it.
--- Ken
"In theory, theory and practice are the same, but in practice they're not." -- Yogi Berra
Thu Feb 25, 2021 8:04 am
Thank you for your question
Put devices into maintenance mode (StarWind VSAN for Hyper-V): https://www.starwindsoftware.com/resour ... owerchute/ please note that it is a sample script: you need to add the part where you shut down the VMs on your own.
Recommended shut-down procedure https://knowledgebase.starwindsoftware. ... installed/
wallewek
Thu Feb 25, 2021 8:18 pm
Thank you Yaroslav. That's a start.
Here's something that aligns to what I have in mind. I would suggest StarWind provide at least a template script that could be used with Windows Group Policy, as in Local Computer Policy | Computer Configuration | Windows Settings | Scripts (Startup/Shutdown).
See
https://stackoverflow.com/questions/124 ... s-shutdown
or
https://docs.microsoft.com/en-us/previo ... v=msdn.10)
https://docs.microsoft.com/en-us/previo ... 0(v=ws.11)
Fri Feb 26, 2021 10:53 am
Hey Ken,
Thanks for the links. Is there anything I can assist you with?
P.s. MS docs are 404 pages :(
wallewek
Fri Feb 26, 2021 10:32 pm
Thanks Yaroslav, no, unless you have anything else for this, I can take what you sent to see what makes sense for my needs.
Re the MS docs... yes, that sounds like them. They love to make a short story long. ;-)
Sat Feb 27, 2021 4:03 am
Ken,
No, I have no additional articles to share.
Have a nice weekend :)
