Large Data 3-Way Synchronous Mirrors
CRD_MWCIT
Mon Jan 18, 2021 5:36 pm
Hello everyone!
My team and I are having trouble getting a 3-Way Synchronous mirror setup on our new storage enclosures from Dell. We are feeding the iSCSI storage to 4x vmware vsphere 7.0U1 hosts
We are currently stable with 2-Way Sync. When we attempt a full-sync of the 3rd SAN we immediately begin experiencing performance issues on the sync partner. We also begin receive error logs indicating underlying storage taking longer than expected and partner node taking longer than expected to respond. For example
"command "WRITE". Request execution time is longer than expected. Response time is 13 sec."
The 3 storage nodes consist of the following hardware
The Starwind host is a Dell Poweredge r740xd with Windows Server 2016 Datacenter
The storage enclosure is a Dell Powervault ME4084 with 56x 12TB 7200RPM SAS drives
The iSCSI Network is 2x 10GbE Mellanox ConnectX-4 LX and Dell S4048-ON switches
The Sync Network is 2x 40GbE Mellanox ConnectX-4 and Dell S6010-ON switches
I have attached a diagram of the hardware setup.
Any help would be greatly appreciated, I am happy to send more information and system logs if needed
Starwind Big Data.png (117.83 KiB) Viewed 13450 times
Replication Node Interfaces.png (14.45 KiB) Viewed 13450 times
Mon Jan 18, 2021 8:29 pm
Welcome to StarWind forum. Can I have the logs from your system, please? What RAID level do you use?
Please note that delays during full synchronization are expected as full synchronization is a resource consuming process. Use this tool to collect the logs from all storage boxes https://knowledgebase.starwindsoftware. ... collector/. Share them via OneDrive or Google Disk.
In your description, you mentioned only one server, but you are discussing a 2-way mirror here. Could you pelase tell me how many storage servers do you have?
Please use IPs from different subnets for iSCSI.
CRD_MWCIT
Mon Jan 18, 2021 9:04 pm
Thank you Yaroslav,
We have 3 nodes, all nodes have the exact same hardware
3x Dell Poweredge r740xd with Windows Server 2016 Datacenter
3x Dell Powervault ME4084 with 56x 12TB 7200RPM SAS drives
I will split the A and B iSCSI channels into 192.168.95.x and 192.168.96.x subnets and I will gather logs for you
Mon Jan 18, 2021 9:08 pm
Greetings
What is the RAID level used for storage boxes?
CRD_MWCIT
Tue Jan 19, 2021 4:37 pm
I have attached a clearer diagram. I still need to change iSCSI to separate subnets but this will require time since we have production data on the storage already
Starwind 3-Way.png (207.79 KiB) Viewed 13408 times
Thu Jan 21, 2021 9:22 pm
Greetings,
I noticed the delays on the first server will be investigating that further.
