ESX to HyperV, no D: drive
MichaelMcNally
Thu Dec 03, 2020 8:49 pm
I exported a Windows 2012R2 server from ESX 6.0 to Hyper-V (server 2019). The system boots and everything works but the export did not include the D: drive from the 2012R2 server.
The D: drive in VMWare is a separate VMDK file but is stored on the same datastore.
For now, I'm manually copying the data from one server to the other using Robocopy. I'm wondering though is there a way to make sure that all disks are copied when converting?
MichaelMcNally
Thu Dec 03, 2020 10:38 pm
Well, it turns out that the drive was copied. In the 2019 Hyper-V server, the drive was offline. Set it to online and all was good.
That was unexpected.
Fri Dec 04, 2020 6:42 am
Hi Michael,
So, was the issue resolved?
