the issue with trail license expiration check.
BenM
Thu Dec 03, 2020 1:40 pm
>>Most likely you were hit by the issue with trail license expiration check..... For now the workaround is to downgrade to build 12767 or 12658 depending on which of them you used before the update.
Using VSAN Free...
Is this bug now fixed?
I really don't want to update and find that it isn't!
Thu Dec 03, 2020 1:55 pm
BenM
Fri Dec 04, 2020 7:45 am
Thanks Yaroslav,
Now just got to find a time that I can do the upgrade :D
Ben
Fri Dec 04, 2020 9:23 am
Ben,
Let me know if there's anything I can assist you with.
