ESXi to Hyper-V - Network Name cannot be found
zane
Tue Nov 10, 2020 9:30 pm
I am trying to do a ESXi to Hyper-V Cluster migration, and it looks like its going to work, but after about 10 minutes it says:
Creating output image file
Error creating image
The network name cannot be found.
Convertation failed
I have found the log file with this in it:
The log file name: 'logs\V2V_Log-20201111-081131.log' (PID 23452)
Delete log file 'logs\V2V_Log-20200930-163627.log'.
11/11 8:11:31.602 6324 Facility ???INFO: CV2V_ConverterApp::InitInstance: SetDllDirectory: C:\Program Files\StarWind Software\StarWind V2V Converter\lib
11/11 8:11:31.602 6324 Facility ???INFO: CV2V_ConverterApp::InitInstance: File Version: 9.0.0.202
11/11 8:11:31.604 6324 Facility ???INFO: CV2V_ConverterApp::InitInstance: Load language IDR_XML_ENGLISH
11/11 8:11:31.604 6324 Facility ???INFO: CV2V_ConverterApp::InitInstance: Load language IDR_XML_RUSSIAN
11/11 8:11:31.604 6324 Facility ???INFO: CV2V_ConverterApp::InitInstance: Set current language English
11/11 8:11:31.604 6324 Facility ???INFO: CPS_V2V_Converter::CPS_V2V_Converter: Version MajorVersion 10, MinorVersion 0, BuildNumber 17763
11/11 8:11:31.606 6324 Facility ???INFO: WrapperHyperV::WrapperHyperV: LoadLibrary C:\Windows\system32\wbem\wmiutils.dll - 990d0000
11/11 8:11:35.921 6324 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eESXConnection
11/11 8:11:51.337 6324 Facility ???INFO: WrapperESXI::connect: m_url - https://10.27.186.30/sdk
11/11 8:11:51.398 6324 Facility ???INFO: WrapperESXI::connect: fullName - Administrator, key - 52d4c9e6-b0f3-9e33-5c7b-d9a4a582ccee
11/11 8:11:51.404 6324 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eInputVM
11/11 8:11:51.515 6324 Facility ???INFO: VMConverter::ESXIConverter::GetHostListInfo: ESX version: 6.5.0
11/11 8:11:57.866 6324 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eLocationTo
11/11 8:12:00.928 6324 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eHYPERVConnectionTo
11/11 8:12:05.116 6324 Facility ???INFO: WrapperHyperV::connect: Host - \\mycluster\root\virtualization\v2
11/11 8:12:05.233 6324 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eVMSettingsHyperV
11/11 8:12:51.634 6324 Facility ???ERROR: HyperVSelectFolderDlg::FillItemExpanded: FindFirstFile - 67
11/11 8:13:56.098 6324 Facility ???ERROR: HyperVSelectFolderDlg::FillItemExpanded: FindFirstFile - 67
11/11 8:22:49.908 6324 Facility ???INFO: VMConverter::HyperVConverter::GetHostListInfo: HyperV version: 10.0.17763
11/11 8:22:49.908 6324 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eConverting
11/11 8:22:49.914 62bc Facility ???INFO: CPPConverting::Convert: InConvertType: 6, OutConvertType: 8
11/11 8:22:50.458 62bc Facility ???INFO: WrapperHyperV::modify_cpu_and_memory: MaxCPU - 32
11/11 8:22:50.530 62bc Facility ???INFO: WrapperHyperV::getMaxMemory: MaxRAM - 752602
11/11 8:22:50.776 62bc Facility ???INFO: CPPConverting::ConverterHyperV: Create VM 538ED3DC-07B6-45A2-8FCE-CF34A3D35F83
11/11 8:22:50.817 62bc Facility ???INFO: CPPConverting::ConvertImage: pathInput: [T1-3tb-d4] vm-test/vm-test.vmdk, pathOutput: C:\ClusterStorage\Volume1\vm-test-fromstarwind-nonic\Virtual Hard Disks\vm-test.vhdx
11/11 8:22:51.252 62bc Facility ???INFO: ESXVmdk::ParseFile: sFilename - [T1-3tb-d4] vm-test/vm-test.vmdk
11/11 8:22:51.252 62bc Facility ???INFO: ESXVmdk::ParseFile: m_cSSLThumbprint - 85:4F:D6:38:2E:AA:86:BE:6E:8C:E8:48:E4:5D:AB:2D:25:D8:E5:B6
11/11 8:22:51.252 62bc Facility ???INFO: ESXVmdk::ParseFile: m_cvmxSpec - [T1-3tb-d4] vm-test/vm-test.vmx
11/11 8:22:51.909 62bc Facility ???INFO: CPPConverting::ConvertImage: CreateInputImage: 0
11/11 8:23:56.871 62bc Facility ???WARNING: HyperVDisk::CreateOutputImage: Error create directory 67 - \\mycluster\C$\ClusterStorage\Volume1\vm-test-fromstarwind-nonic\Virtual Hard Disks. The network name cannot be found.
11/11 8:23:56.873 62bc Facility ???INFO: MicrosoftFile::NewFile: sFilename - \\mycluster\C$\ClusterStorage\Volume1\vm-test-fromstarwind-nonic\Virtual Hard Disks\vm-test.vhdx, nMaxSize - 167772160, fileType - 1
11/11 8:26:05.974 62bc Facility ???ERROR: MicrosoftFile::NewFile: CreateVirtualDisk is fail - 67. The network name cannot be found.
11/11 8:26:05.974 62bc Facility ???INFO: CPPConverting::ConvertImage: CreateOutputImage: 1
11/11 8:26:05.987 62bc Facility ???ERROR: CPPConverting::Convert: FAILED
I know I cant get to \\mycluster\C$, would this be my issue? I dont believe a Windows 2019 cluster shares c$ from the cluster does it? Does this process not work to a 2019 cluster?
Any ideas please?
I have tried it on a VM without a NIC, and I get the same error.
I have tried migrating direct to a Host (not the cluster), and that works, but it adds an additional step of migrating from host to cluster which i would prefer not to do.
What network is it looking for?
thanks
Wed Nov 11, 2020 8:33 am
Thank you for your question.
I am afraid that NIC has nothing to do with this error.
You are right.
May I wonder if you are running conversion from GUI or CLI? I mean, were you able to navigate to this folder from the GUI?
zane
Wed Nov 11, 2020 10:30 am
running from the GUI. in the interface i get what is in the attached image. I am not able to browse the subfolders, even though there are subfolders and they have running VMs in them.
Screenshot
Screenshot
Thu Nov 12, 2020 10:37 am
Greetings,
Is it possible to convert the VM locally and then do storage migration to CSV? Did you run V2V as an administrator?
Let me know if any assistance is reuired.
zane
Thu Nov 12, 2020 6:44 pm
Yes, running as Admin.
At he moment, I am running it to a Host (then I can navigate to the shared storage) and its working ok, but then to get the cluster to own it have to do a import (storage migration wont do it) to the cluster, which clones the virtual disks back to the same physical disks its already on. So its a slow process, and wont work for my very large VMs
Fri Nov 13, 2020 8:32 am
We have explicitly tested your conversion scenario in our lab and it worked fine.
That's right. Will this workaround work for you?
edbrittain
Tue Dec 15, 2020 7:47 am
You can convert the VM locally and then do storage migration to CSV.
Tue Feb 27, 2024 1:37 pm
Yes!
+ We support live conversion with V2V now, you don't need to stop your virtual machine when converting.
edbrittain wrote: ↑
TurboTurbo
Tue May 21, 2024 5:14 pm
anton (staff) wrote: ↑
Yes!
edbrittain wrote: ↑
Hey Anton,
Sorry to bring up an old thread and hijacking, what is the success rate of doing a live migration. I'm in the process of switching over from VM to Hyper V and we have customers who can have little to no down time. How many times are snapshots taken during the conversion?
Apologies for my ignorance never used a V2V converter before.
If needed I can create a new thread.
Thu May 23, 2024 9:18 pm
Sorry for the delay and welcome to StarWind Forum. StarWind V2V can convert the VMs live. it makes only one snapshot and merges it at the end.
