Wed Nov 04, 2020 11:20 am
Thank you for your reply.
We are aware of the documentation. The sync is running. We used a script to mark as sync the volume and it worked.
But still that's not what we expected.
"After all nodes of the HA cluster were down, StarWind is by default able to determine which node holds the most recent data and starts the synchronization process automatically if all nodes are online." => We were expecting that and when we did some tests we had this result. The sync will start over and over but at least the volumes were UP...
"In case when StarWind services can not determine which node contains the most recent data they block all incoming connections to prevent data corruption until one of the HA partners is marked as Synchronized." => that's the problem...
registerSession: Client initiator iqn.1991-05.com.microsoft:****************.int is trying to register a session within the 'iqn.2008-08.com.starwindsoftware:**************-csv1' target... (sessId = 0x14, initiatorNameIsid = iqn.1991-05.com.microsoft:*******,400001370003)
11/2 14:16:24.860396 ad4 HA: HASyncNode::registerSession: Unable to register the new client session. The node is not active!
11/2 14:16:24.860407 ad4 HA: HASyncNode::registerSession: Return code 21.
11/2 14:16:24.860423 ad4 Tgt: *** iScsiTarget::openSession: iqn.2008-08.com.starwindsoftware:********: can't register session. The device 'HAImage1' is not ready.
11/2 14:16:24.860435 ad4 T[14,1]: ***iScsiTask::startLoginPhase: *ERROR* Login request: device open failed.
11/2 14:16:24.860513 20d0 C[14], IN_LOGIN: iScsiConnection::doTransition: Event - LOGIN_REJECT.
11/2 14:16:24.860640 ad4 debug: *** Swn_SocketRecv: WSARecv() failed with error 10054 (0x2746)!
11/2 14:16:24.860663 ad4 Srv: *** SwSocket::Recv: Swn_SocketRecv() failed with error 10054 (0x2746)!
