Veeam Cannot lock tape drive
clark kent
Tue Oct 27, 2020 4:29 am
Hi Team,
I have been trying to setup mine Veem B&R with the Starwind VTL free version.
The configuration process really goes smoothly, apparently without issues.
I was able to create the Target, the VTL devices and the tapes using the powersheel scripts, and seems that everything is fine.
Configured the Windows Server 2019 to connect in the iSCSI, and after updated the LTO drivers to use the HPE one.
From inside of the Veeam, I was able to detect the new Library, and also, see the two medias available.
Now, when I try to "Inventory the tape" or "erase tape", I always receive the error Unable to perform Tape erase for library HP MSL G3 Series 9.50: cannot lock tape drive
I have been struggling on this issue along the day today.... :(
Does someone already faced this issue? Some idea what could be the error here?
Veeam Print Scree error.
Tue Oct 27, 2020 6:41 am
Looks like you are not alone https://forums.veeam.com/tape-f29/featu ... 68063.html.
please see this thread. Let me know if that works for you.
PrarirGeta
Fri Oct 30, 2020 1:50 pm
I have been struggling on this issue for quite a while now too and the solution above didn't solve my problem.
Fri Oct 30, 2020 6:48 pm
Welcome to StarWind Forum. Did you try contacting Veeam on those error codes?
aaa
Sun Dec 22, 2024 4:29 pm
Hello
I resolve it by updating driver of my "tape drivers" driver in device manger.
you can search the complete name of your tape driver , download and install then enjoy. :D
for hp ultrium 6-scsi scsi sequential device driver you can use this link :
https://downloads.hpe.com/pub/softlib2/ ... 049429.exe
Sun Dec 22, 2024 8:12 pm
Many thanks!
sinda dridi
Thu Mar 06, 2025 11:31 am
I have same Error :
" Failed to inventory tape COT716L6 Error: Failed to call RPC function 'LoadMediumByScsi': Fixed format, current; Sense key: Illegal Request. Incompatible volume qualifier.
Failed to perform scsi command. CDB: a5 00 00 00 03 fe 00 01 00 00 00 00."
knowing that Drive is hp msl g3 series 7.90 LTO 8 and tape LTO6.
Case : need to restore data from old tape.
Thu Mar 06, 2025 1:59 pm
Is it a tape or virtual tape?
RPC server is something on the host side. Try restarting the server.
