one VM has multiple VMDK files convert to VHD Issue
andy.feng
Fri Oct 16, 2020 8:26 am
Hi There,
I have a VMWare VM, it has multiple VMDK files and I want this VM can run in a Hyper-V server.
how should i do?
convert the vmdk files one by one to vhd files? and then create a hyper-v vm and attached these vhd files ?
vmdk files.png (25.77 KiB) Viewed 14709 times
vm infor.png (194.19 KiB) Viewed 14709 times
andy.feng
Fri Oct 16, 2020 8:28 am
please help.
Fri Oct 16, 2020 9:02 am
Please turn off the VM and convert it. https://www.starwindsoftware.com/v2v-he ... erver.html
Alternatively, try converting disks one by one with the repair mode enabled. https://www.starwindsoftware.com/v2v-he ... erver.html
edbracco
Wed Dec 16, 2020 1:57 am
You should turn off the VM and convert it.
Wed Dec 16, 2020 7:00 am
That's right to turn off VMs before conversion.
HarberCandelario
Mon Jan 04, 2021 1:22 am
The instance is going to be a single system ... the VMX file represents the entire Virtual Machine.
the .NVRAM (when running) is just that ... NVRAM.
There is a vswp (virtual swap file), VMDK (Virtual machine Disk).
Even with Virtual Server, you have VMC (virtual machine configuration), VHD (Virtual Hard Disk) ...
It sounds like you want all of the files that comprise a VM put into one (like an archive or something).
That's not the average virtual machine.
Last edited by HarberCandelario on Sat Jan 09, 2021 2:54 am, edited 1 time in total.
Mon Jan 04, 2021 5:01 am
Thank you for such a detailed explanation.
