health status using powershell
Locked
abhi2101
Fri Sep 25, 2020 7:06 am
How can I get health status using powershell ?
Fri Sep 25, 2020 7:28 am
Greetings,
You've got the script in C:\Program Files\StarWind Software\StarWind\StarWindX\Samples\powershell called SyncHaDeviceAdvanced. Type the device name there and use it to check StarWind HA device sync status.
abhi2101
Fri Sep 25, 2020 7:45 am
can you please provide an example ?
Fri Sep 25, 2020 7:59 am
Greetings,
HAdeviceAdvanced works for all devices; no need to specify the specific HA device. Just run the script.
stefanheisles
Tue Mar 28, 2023 9:57 am
It's extremely good to see that you are exploring different ways to get fitness status using PowerShell. The script you mentioned, SyncHaDeviceAdvanced, can be a beneficial tool for checking the sync status of your StarWind HA device. To supply an example, you can simply open PowerShell and navigate to the directory the place the script is located, which is typically "C:\Program Files\StarWind Software\StarWind\StarWindX\Samples\powershell".
From there, you can run the script and kind in the discover of the gadget you desire to check. It's essential to note that the HAdeviceAdvanced script works for all devices, so you don't want to specify a specific HA device. This can be a quick and handy way to check the health fame of your devices using PowerShell.
Tue Mar 28, 2023 11:20 am
You are right.
MariaWard
Wed Mar 29, 2023 7:11 pm
stefanheisles wrote:It's extremely good to see that you are exploring different ways to get fitness status using PowerShell. The script you mentioned, SyncHaDeviceAdvanced, can be a beneficial tool for checking the sync status of your StarWind HA device. To supply an example, you can simply open PowerShell and navigate to the directory the place the script is located, which is typically "C:\Program Files\StarWind Software\StarWind\StarWindX\Samples\powershell".
I think this is an exhaustive answer, thank you for this discussion
Tue Feb 27, 2024 1:24 pm
Closing this thread for purity...
== thread closed ==
Locked
