P2V Conversion Finished Succesfully in Seconds but failed
dcgibb
Sat Sep 19, 2020 8:17 pm
Converting a Physical to Virtual on ESXi 6.7 and the conversion starts and finished with a response it completes successfully.
when trying to boot the newly created VM there was actually no converted HDD transferred over. Logs show up weird tried to
the LUN Storage on the Esxi server and the physical disks same results. Logs are posted below any help would be great. Side
note I have done about 6 of these no problems and this is the first one giving me greif
Logs:
The log file name: 'logs\V2V_Log-20200919-160756.log' (PID 4892)
9/19 16:07:56.310 1364 Facility ???INFO: CV2V_ConverterApp::InitInstance: SetDllDirectory: C:\Program Files\StarWind Software\StarWind V2V Converter\lib
9/19 16:07:56.310 1364 Facility ???INFO: CV2V_ConverterApp::InitInstance: File Version: 9.0.0.202
9/19 16:07:56.310 1364 Facility ???INFO: CV2V_ConverterApp::InitInstance: Load language IDR_XML_ENGLISH
9/19 16:07:56.310 1364 Facility ???INFO: CV2V_ConverterApp::InitInstance: Load language IDR_XML_RUSSIAN
9/19 16:07:56.310 1364 Facility ???INFO: CV2V_ConverterApp::InitInstance: Set current language English
9/19 16:07:56.310 1364 Facility ???INFO: CPS_V2V_Converter::CPS_V2V_Converter: Version MajorVersion 6, MinorVersion 2, BuildNumber 9200
9/19 16:07:56.326 1364 Facility ???INFO: WrapperHyperV::WrapperHyperV: LoadLibrary C:\Windows\system32\wbem\wmiutils.dll - 3f530000
9/19 16:08:00.295 1364 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eTypeP2V
9/19 16:08:04.716 1364 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eVolumeSelectVM
9/19 16:08:06.404 1364 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eLocationTo
9/19 16:08:08.654 1364 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eESXConnectionTo
9/19 16:08:25.123 1364 Facility ???INFO: WrapperESXI::connect: m_url - https://10.10.200.5/sdk
9/19 16:08:25.217 1364 Facility ???INFO: WrapperESXI::connect: fullName - Administrator, key - 52ac0f61-12ce-8296-0024-f84511e4c376
9/19 16:08:25.248 1364 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eVMSettingsESX
9/19 16:08:39.702 1364 Facility ???WARNING: ESXiSelectFolderDlg::FillItemExpanded: HttpSendRequest 1 /folder?dcPath=ha-datacenter&dsName=WRFP-ISO-DS - 12029. ERROR_INTERNET_CANNOT_CONNECT
9/19 16:08:39.718 1364 Facility ???WARNING: ESXiSelectFolderDlg::FillItemExpanded: HttpSendRequest 1 /folder?dcPath=ha%2ddatacenter&dsName=WRFP-ISO-DS - 12029. ERROR_INTERNET_CANNOT_CONNECT
9/19 16:08:39.733 1364 Facility ???WARNING: ESXiSelectFolderDlg::FillItemExpanded: HttpSendRequest 1 /folder?dcPath=ha%252ddatacenter&dsName=WRFP-ISO-DS - 12029. ERROR_INTERNET_CANNOT_CONNECT
9/19 16:08:39.733 1364 Facility ???WARNING: ESXiSelectFolderDlg::FillItemExpanded: strTemp is empty
9/19 16:08:50.030 1364 Facility ???WARNING: ESXiSelectFolderDlg::FillItemExpanded: HttpSendRequest 1 /folder?dcPath=ha-datacenter&dsName=WRFP-VMHost-01-LocalDS - 12029. ERROR_INTERNET_CANNOT_CONNECT
9/19 16:08:50.046 1364 Facility ???WARNING: ESXiSelectFolderDlg::FillItemExpanded: HttpSendRequest 1 /folder?dcPath=ha%2ddatacenter&dsName=WRFP-VMHost-01-LocalDS - 12029. ERROR_INTERNET_CANNOT_CONNECT
9/19 16:08:50.061 1364 Facility ???WARNING: ESXiSelectFolderDlg::FillItemExpanded: HttpSendRequest 1 /folder?dcPath=ha%252ddatacenter&dsName=WRFP-VMHost-01-LocalDS - 12029. ERROR_INTERNET_CANNOT_CONNECT
9/19 16:08:50.061 1364 Facility ???WARNING: ESXiSelectFolderDlg::FillItemExpanded: strTemp is empty
9/19 16:09:02.390 1364 Facility ???INFO: VMConverter::ESXIConverter::GetHostListInfo: ESX version: 6.7.0
9/19 16:09:02.468 1364 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eConverting
9/19 16:09:02.483 e58 Facility ???INFO: CPPConverting::Convert: InConvertType: 3, OutConvertType: 6
9/19 16:09:02.483 e58 Facility ???INFO: CheckFileESX::CheckFileExistance: /folder/WRFP-Pinter/HDD0.vmdk?dcPath=ha-datacenter&dsName=WRFP-VMHost-01-LocalDS
9/19 16:09:02.499 e58 Facility ???WARNING: CheckFileESX::CheckFileExistance: HttpSendRequest is fail - ERROR_INTERNET_CANNOT_CONNECT
9/19 16:09:02.499 e58 Facility ???INFO: CheckFileESX::SetError: Internet Error Code - 12029
9/19 16:09:02.499 e58 Facility ???INFO: CheckFileESX::SetError: Error info - A connection with the server could not be established
9/19 16:09:02.499 e58 Facility ???INFO: CheckFileESX::CheckFileExistance: /folder/WRFP-Pinter/HDD0.vmdk?dcPath=ha%2ddatacenter&dsName=WRFP-VMHost-01-LocalDS
9/19 16:09:02.515 e58 Facility ???WARNING: CheckFileESX::CheckFileExistance: HttpSendRequest is fail - ERROR_INTERNET_CANNOT_CONNECT
9/19 16:09:02.515 e58 Facility ???INFO: CheckFileESX::SetError: Internet Error Code - 12029
9/19 16:09:02.515 e58 Facility ???INFO: CheckFileESX::SetError: Error info - A connection with the server could not be established
9/19 16:09:02.515 e58 Facility ???INFO: CheckFileESX::CheckFileExistance: /folder/WRFP-Pinter/HDD0.vmdk?dcPath=ha%252ddatacenter&dsName=WRFP-VMHost-01-LocalDS
9/19 16:09:02.546 e58 Facility ???WARNING: CheckFileESX::CheckFileExistance: HttpSendRequest is fail - ERROR_INTERNET_CANNOT_CONNECT
9/19 16:09:02.546 e58 Facility ???INFO: CheckFileESX::SetError: Internet Error Code - 12029
9/19 16:09:02.546 e58 Facility ???INFO: CheckFileESX::SetError: Error info - A connection with the server could not be established
9/19 16:09:02.796 e58 Facility ???INFO: VMConverter::ESXIConverter::CreateVM: createVM is true, 36
9/19 16:09:02.796 e58 Facility ???INFO: CPPConverting::ConverterESX: Create VM 36
9/19 16:09:03.171 e58 Facility ???INFO: CPPConverting::Convert: SUCCESSFULLY
Mon Sep 21, 2020 3:29 am
These lines make me think that there are some problems with accessing the target file.
/folder/WRFP-Pinter/HDD0 is this location of the target file? Try converting the VMDK alone.
