P2V Win7 pro to VHD's Blue Screen
Elohnroc
Sun Sep 06, 2020 11:49 am
This is driving me nuts.
Using StarWind I imaged the physical disks from a Win7 Pro 64b to VHD's
Physical machine has two disks:
C: - contains a system partition and the C: drive partition
E: - contains a system reserved partition and the E: drive
Upon starting the VM in VirtualBox, just after the Windows splash/startup screen, I blue screen with a 0x07b code. Is see many others having this same problem. I have re-imaged these drives several times with the same result. I have tried imaging the C: drive as one disk, as well as the partitions individually, with the same results. I have attempted to change the storage controller to other controlers, i.e., SATA, IDE, etc with no change in outcome.
I have done this before with other similar Win7 machines with no issues. This Physical machine starts up and functions with no hardware issues.
For the life of me, I can not figure out what is going on here. Any help in next-step troubleshooting would be appreciated. Attaching logs from latest Virtual Box startup attempt.
VBox.zip
(50.39 KiB) Downloaded 492 times
Wed Sep 09, 2020 3:19 am
Greetings,
Please try running conversion in a repair mode.
Elohnroc
Thu Sep 10, 2020 10:40 am
Thank you. Not sure what that means, I assume it means during the conversion of disks to VHD's there is a repair mode. I will find details on how-to and report back results.
Thanks again.
kd
Thu Sep 10, 2020 10:54 am
Greetings,
While doing P2V Conversion there should be an option to run in the repair mode.
