CentOS7 failed from Esxi 6.5 to Windows Server 2019 HELP!
root@
Sun Sep 06, 2020 1:48 am
Howdy guys, :D
As title says. When I convert Centos 7 distro (PBX) to 2019 Hyper-V and fire up vm, it fails to boot saying root not found, also /dev/sangoma/swap not found. And bunch of stuff not found.
The conversion process finishes 100% no errors there, the vm looks identical as on esxi in terms of CPU, RAM.
The only thing that bugs me is original vm is 225GB but used is about 64GB, so V2V converts it as only 64GB, is it possible that it actually missies rest of the drive and therefore my converted vm won’t start properly?
If that’s the case what do I do?
Thanks.
root@
Tue Sep 08, 2020 5:03 am
Anyone? Any idea? :idea:
Tue Sep 08, 2020 5:23 am
Hey,
I will check this with my colleague and reach out to you shortly.
Can I have the log please? You can find it here C:\Program Files\StarWind Software\StarWind V2V Converter\logs.
root@
Tue Sep 08, 2020 5:58 am
Thank you for quick response.
Here are some latest logs close by the timestamp:
The log file name: 'logs\V2V_Log-20200904-221806.log' (PID 11136)
9/4 22:18:06.760 262c Facility ???INFO: CV2V_ConverterApp::InitInstance: SetDllDirectory: C:\Program Files\StarWind Software\StarWind V2V Converter\lib
9/4 22:18:06.760 262c Facility ???INFO: CV2V_ConverterApp::InitInstance: File Version: 9.0.0.202
9/4 22:18:06.775 262c Facility ???INFO: CV2V_ConverterApp::InitInstance: Load language IDR_XML_ENGLISH
9/4 22:18:06.775 262c Facility ???INFO: CV2V_ConverterApp::InitInstance: Load language IDR_XML_RUSSIAN
9/4 22:18:06.775 262c Facility ???INFO: CV2V_ConverterApp::InitInstance: Set current language English
9/4 22:18:06.775 262c Facility ???INFO: CPS_V2V_Converter::CPS_V2V_Converter: Version MajorVersion 10, MinorVersion 0, BuildNumber 17763
9/4 22:18:06.791 262c Facility ???INFO: WrapperHyperV::WrapperHyperV: LoadLibrary C:\Windows\system32\wbem\wmiutils.dll - ae9e0000
9/4 22:18:12.072 262c Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eESXConnection
9/4 22:19:05.469 262c Facility ???INFO: WrapperESXI::connect: m_url - https://67.155.192.36/sdk
9/4 22:19:05.891 262c Facility ???INFO: WrapperESXI::connect: fullName - Administrator, key - 52524cec-7541-07ec-6d2d-0fb25fdaa750
9/4 22:19:05.954 262c Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eInputVM
9/4 22:19:06.235 262c Facility ???INFO: VMConverter::ESXIConverter::GetHostListInfo: ESX version: 6.5.0
9/4 22:19:10.423 262c Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eLocationTo
9/4 22:19:16.597 262c Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eHYPERVConnectionTo
9/4 22:19:18.488 262c Facility ???INFO: WrapperHyperV::connect: Host - \\localhost\root\virtualization\v2
9/4 22:19:18.787 262c Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eVMSettingsHyperV
9/4 22:19:43.452 262c Facility ???INFO: VMConverter::HyperVConverter::GetHostListInfo: HyperV version: 10.0.17763
9/4 22:19:43.483 262c Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eConverting
9/4 22:19:43.483 bf0 Facility ???INFO: CPPConverting::Convert: InConvertType: 6, OutConvertType: 8
9/4 22:19:43.952 bf0 Facility ???INFO: WrapperHyperV::modify_cpu_and_memory: MaxCPU - 16
9/4 22:19:43.999 bf0 Facility ???INFO: WrapperHyperV::getMaxMemory: MaxRAM - 29916
9/4 22:19:44.249 bf0 Facility ???INFO: VMConverter::HyperVConverter::CreateVM: add_ethernet_connection is 1
9/4 22:19:44.249 bf0 Facility ???INFO: CPPConverting::ConverterHyperV: Create VM 72C298A4-FAD2-4563-9A2C-6C7A237EA6E1
9/4 22:19:44.265 bf0 Facility ???INFO: CPPConverting::ConvertImage: pathInput: [datastore1] Voip/Voip_0.vmdk, pathOutput: C:\VHD\Voip\Virtual Hard Disks\Voip_0.vhdx
9/4 22:19:45.046 bf0 Facility ???INFO: ESXVmdk::ParseFile: sFilename - [datastore1] Voip/Voip_0.vmdk
9/4 22:19:45.046 bf0 Facility ???INFO: ESXVmdk::ParseFile: m_cSSLThumbprint - 94:DE:B0:DF:D6:3C:DA:D6:EF:A6:25:89:A0:17:AE:03:87:2B:3E:83
9/4 22:19:45.046 bf0 Facility ???INFO: ESXVmdk::ParseFile: m_cvmxSpec - [datastore1] Voip/Voip.vmx
9/4 22:19:46.437 bf0 Facility ???INFO: CPPConverting::ConvertImage: CreateInputImage: 0
9/4 22:19:47.265 bf0 Facility ???INFO: MicrosoftFile::NewFile: sFilename - \\localhost\C$\VHD\Voip\Virtual Hard Disks\Voip_0.vhdx, nMaxSize - 134217728, fileType - 1
9/4 22:19:47.296 bf0 Facility ???INFO: CPPConverting::ConvertImage: CreateOutputImage: 0
9/4 22:43:06.896 bf0 Facility ???INFO: CPPConverting::ConvertImage: Success
9/4 22:43:07.037 bf0 Facility ???INFO: WrapperHyperV::connect: Host - \\localhost\root\virtualization\v2
9/4 22:43:07.209 bf0 Facility ???INFO: VMConverter::HyperVConverter::AddVirtualDisk: add_disk_synthetic __pathVirtualSystem - \\NBA-SF-HOST\root\virtualization\v2:Msvm_VirtualSystemSettingData.InstanceID="Microsoft:72C298A4-FAD2-4563-9A2C-6C7A237EA6E1", controller - \\NBA-SF-HOST\root\virtualization\v2:Msvm_ResourceAllocationSettingData.InstanceID="Microsoft:72C298A4-FAD2-4563-9A2C-6C7A237EA6E1\\83F8638B-8DCA-4152-9EDA-2CA8B33039B4\\0", numLoc - 0
9/4 22:43:07.271 bf0 Facility ???INFO: VMConverter::HyperVConverter::AddVirtualDisk: add_disk_synthetic 1 \\NBA-SF-HOST\root\virtualization\v2:Msvm_ResourceAllocationSettingData.InstanceID="Microsoft:72C298A4-FAD2-4563-9A2C-6C7A237EA6E1\\83F8638B-8DCA-4152-9EDA-2CA8B33039B4\\0\\0\\D"
9/4 22:43:07.388 bf0 Facility ???INFO: VMConverter::HyperVConverter::AddVirtualDisk: add_disk_virtual path C:\VHD\Voip\Virtual Hard Disks\Voip_0.vhdx 1
9/4 22:43:07.388 bf0 Facility ???INFO: CPPConverting::Convert: SUCCESSFULLY
9/4 22:57:44.935 262c Facility ???WARNING: WrapperESXI::disconnect: m_proxy->Logout fail - 12
9/4 22:57:44.935 262c Facility ???ERROR: getErrorFromSOAP: soap_sprint_fault - SOAP 1.1 fault "":ServerFaultCode [no subcode]
Detail:
The log file name: 'logs\V2V_Log-20200904-214046.log' (PID 8648)
9/4 21:40:46.836 560 Facility ???INFO: CV2V_ConverterApp::InitInstance: SetDllDirectory: C:\Program Files\StarWind Software\StarWind V2V Converter\lib
9/4 21:40:46.836 560 Facility ???INFO: CV2V_ConverterApp::InitInstance: File Version: 9.0.0.202
9/4 21:40:46.836 560 Facility ???INFO: CV2V_ConverterApp::InitInstance: Load language IDR_XML_ENGLISH
9/4 21:40:46.836 560 Facility ???INFO: CV2V_ConverterApp::InitInstance: Load language IDR_XML_RUSSIAN
9/4 21:40:46.836 560 Facility ???INFO: CV2V_ConverterApp::InitInstance: Set current language English
9/4 21:40:46.836 560 Facility ???INFO: CPS_V2V_Converter::CPS_V2V_Converter: Version MajorVersion 10, MinorVersion 0, BuildNumber 17763
9/4 21:40:46.852 560 Facility ???INFO: WrapperHyperV::WrapperHyperV: LoadLibrary C:\Windows\system32\wbem\wmiutils.dll - ae9e0000
9/4 21:40:50.184 560 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eESXConnection
9/4 21:41:12.938 560 Facility ???INFO: WrapperESXI::connect: m_url - https://67.155.192.36/sdk
9/4 21:41:13.001 560 Facility ???INFO: WrapperESXI::connect: fullName - Administrator, key - 52f97dc3-4a55-ed95-6adb-9f748ee21c57
9/4 21:41:13.016 560 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eInputVM
9/4 21:41:13.063 560 Facility ???INFO: VMConverter::ESXIConverter::GetHostListInfo: ESX version: 6.5.0
9/4 21:41:17.914 560 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eLocationTo
9/4 21:41:25.916 560 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eHYPERVConnectionTo
9/4 21:41:27.979 560 Facility ???INFO: WrapperHyperV::connect: Host - \\localhost\root\virtualization\v2
9/4 21:41:28.025 560 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eOutputVM
9/4 21:41:28.244 560 Facility ???INFO: VMConverter::HyperVConverter::GetHostListInfo: HyperV version: 10.0.17763
9/4 21:41:43.512 560 Facility ???WARNING: ConfigNewHyperVVM::OnChangeEdits: Name is fail - Name is empty.
Tue Sep 08, 2020 6:16 am
Thank you
I will contact you once we are done investigating them.
root@
Tue Sep 08, 2020 6:17 am
:D
root@
Tue Sep 08, 2020 5:53 pm
I added screenshot with error here.
Error
Error
v2v error.jpg (97.26 KiB) Viewed 21610 times
root@
Tue Sep 08, 2020 5:54 pm
The swap file on the esxi is about 100 MB.
Thu Sep 10, 2020 7:32 am
HI,
We did log check and conversion has indeed run smoothly. Since you are using a dynamic disk, only 64 GB were converted. There is no data alteration due to conversion in other words.
I am discussing with my colleagues the Linux-related side of the problem which you stumbled into.
root@
Thu Sep 10, 2020 10:34 pm
Thanks let me know asap.
Fri Sep 11, 2020 7:18 am
Have a meeting with those guys on Monday. Will provide you with any news once I have them.
Mon Sep 14, 2020 7:47 am
Greetings,
It seems like swap the OS cannot find the swap file.
Could you tell us where the disks are located and where is the SWAP disk in particular? Run df -h on your CentOS VM?
root@
Mon Sep 14, 2020 4:32 pm
Ok I will run it. I believe all within same datastore...
root@
Mon Sep 14, 2020 5:24 pm
For some reasons the vm has 2 swap files...
Any idea how to include them within exported .vhdx?
Here is that vm datastore content
CentOS datastore.jpg (72.03 KiB) Viewed 21488 times
root@
Mon Sep 14, 2020 5:26 pm
Do I run this on original vm?
