Add node to cluster using Powershell
AlexH
Tue Jul 07, 2020 1:31 pm
Hello, the last 2 weeks I tested Starwind VSan Free and it works perfectly. We'll probably be rolling this out in a remote office as a 2-node cluster. But maybe we'll need to expand to a 3-node cluster if the hardware can't handle the load. It's been asked in the past, but is it already possible to add a node to an existing cluster using Powershell yet? It's been on the roadmap since 2016/2017 looking at older posts. I could only find the Add-HAPartner.ps1 script but I don't think this is for adding a 3rd node to a 2-node cluster.
Wed Jul 08, 2020 2:40 pm
Hi Alex,
Welcome to StarWind Forum!
AddHaPartner can be fit to this task. You need to use interfaces of the 1st and 3rd nodes; interfaces for the 2nd node (the one that has already been added) the module retrieves automatically.
AlexH
Thu Jul 09, 2020 2:45 pm
Hi Yaroslav. Thanks for the info, now the script makes sense! I'll test the expansion this weekend.
Thu Jul 09, 2020 3:14 pm
Please keep me posted. Let me know if you have any other questions.
AlexH
Fri Jul 10, 2020 2:56 pm
yaroslav (staff) wrote:Hi Alex,
I'm looking at the script now, but how will it know the interfaces for the 2nd node? Starwinds advice is in 2 and 3 clusters to use direct connections. The connection from node 2 and 3 will be on other interfaces therefore. It seems to me that I would need to specify also the hb and sync channels for node 2 to be used by node 3. Or do I miss something?
Fri Jul 10, 2020 3:03 pm
It retrieves interfaces of 2nd node from the device info. In other words, StarWind Service should retrieve them automatically.
AlexH
Mon Jul 13, 2020 6:53 am
yaroslav (staff) wrote:It retrieves interfaces of 2nd node from the device info. In other words, StarWind Service should retrieve them automatically.
I've played with it but I don't see how this can work. The script starts as follows:
param($addr="192.168.0.1", $port=3261, $user="root", $password="starwind", $deviceName="HAImage1",
	$addr2="192.168.0.2", $port2=$port, $user2=$user, $password2=$password,
#secondary node
	$imagePath2="My computer\C\starwind",
	$imageName2="partnerImg22",
	$createImage2=$true,
	$targetAlias2="partnerha22",
	$autoSynch2=$true,
	$poolName2="pool1",
	$syncSessionCount2=1,
	$aluaOptimized2=$true,
	$cacheMode2="none",
	$cacheSize2=0,
	$hbInterface2="#p1={0}:3260" -f $addr,
	$selfSyncInterface="#p1={0}:3260" -f $addr2,
	$selfHbInterface="#p1={0}:3260" -f $addr2
This is using the management IP's also for Sync and HB. Also it named p1= in both the interfaces for the existing node ad for the new node. When creating a new 3-node cluster you use p1=, p2= and p3=. I modified the script with the correct hb and sync interfaces but I keep getting invalid partner information.
As recommended by Starwind I use direct connections between all nodes. The current setup has only 1 sync and 1 hb between node 1 and 2.
Mangement IP's
Node-1: 192.168.2.91 (already in cluster)
Node-1: 192.168.2.92 (already in cluster)
Node-1: 192.168.2.93 (new node to be added)
Sync between node 1 and 2: 172.16.10.10 and 172.16.10.20 (already in place and working)
Sync between node 2 and 3: 172.16.11.20 and 172.16.11.30
Sync between node 1 and 3: 172.16.12.10 and 172.16.12.30
HB between node 1 and 2: 172.16.20.10 and 172.16.20.20 (already in place and working)
HB between node 2 and 3: 172.16.21.20 and 172.16.21.30
HB between node 1 and 3: 172.16.22.10 and 172.16.22.30
I would assume I need to change the script as follows:
param($addr="192.168.2.91", $port=3261, $user="root", $password="starwind", $deviceName="HAImage1",
	$addr2="192.168.2.93", $port2=$port, $user2=$user, $password2=$password,
#secondary node
	$autoSynch2=$true,
	$poolName2="pool1",
	$cacheMode2="none",
	$cacheSize2=0,
	$syncInterface2="#p1=172.16.12.10:3260;#p2=172.16.11.20:3260",
	$hbInterface2="#p1=172.16.22.10:3260;#p2=172.16.21.20:3260",
	$selfSyncInterface="#p2=172.16.10.20:3260;#p3=172.16.12.30:3260",
	$selfHbInterface="#p2=172.16.20.20:3260;#p3=172.16.22.30:3260"
But nowhere I need to specify for node-2 which interfaces thát node needs to use. It seems this script is not suitable for this kind of task, or am I missing something?
Running the above results in: 200 Failed: invalid partner info..
Where do I go wrong?
Wed Jul 15, 2020 9:15 am
The last script you provided us with should be the right one.
You do not need to specify node 2 anywhere. Just node 1 p1= and node 2 p2=
Try this one. I used the unique names.
aram($addr="192.168.2.91", $port=3261, $user="root", $password="starwind", $deviceName="HAImage2",
#secondary node
   $imageName2="partnerImg23",
   $targetAlias2="partnerha23",
   $autoSynch2=$true,
   $poolName2="pool1",
   $cacheMode2="none",
   $cacheSize2=0,
   $syncInterface2="#p1=172.16.12.10:3260" -f $addr,
   $hbInterface2="#p1=172.16.22.10:3260" -f $addr,
   $selfSyncInterface="#p1=172.16.12.30:3260" -f $addr2,
   $selfHbInterface="#p1=72.16.22.30:3260" -f $addr2
So, what was wrong with your script?
Node interfaces were mixed: you used interfaces of 2nd node.
p3= is not a variable, i believe.
Use commas to separate IPs (e.g., p2=172.16.12.10:3260,172.16.12.30:3260")
Please consider using the default $imageName2= and $targetAlias2=" values. Please note that you are missing the other part where the variables are enlisted.
Let me know if the script I provided you with works.
AlexH
Wed Jul 15, 2020 1:47 pm
Thanks for your answers. Unfortunately it didn't work. I get the following error:
Request to  TEST-NODE1 ( 192.168.2.91 ) : 3261
control 0x000002783EFFF540 -AddPartner:"" -PartnerTargetName:"#p1=iqn.2008-08.com.starwindsoftware:192.168.2.93-partnerha23" -Priority:"#p1=2" -nodeType:"#p1=1" -P
artnerIP:"#p1=172.16.12.30:sync:3260:1,72.16.22.30:heartbeat:3260:1" -AuthChapType:"#p1=none" -AuthChapLogin:"#p1=0b" -AuthChapPassword:"#p1=0b" -AuthMChapName:"#p
1=0b" -AuthMChapSecret:"#p1=0b" -Replicator:"#p1=0"
200 Failed: operation cannot be completed..
Any other idea?
Wed Jul 15, 2020 1:55 pm
Param($addr="192.168.2.91", $port=3261, $user="root", $password="starwind", $deviceName="HAImage2",
#secondary node
   $autoSynch2=$true,
   $poolName2="pool1",
   $cacheMode2="none",
   $cacheSize2=0,
Try using the default values for $imageName2= and $targetAlias2=" values.
Let me know if that helps.
