commandline v2v from esxi to hyper-v entire vm/all disks
genelaoyan
Sun May 17, 2020 8:47 pm
can the starwind converter commandline product convert an entire vm from esxi to hyper-v?
i have tested the gui version and it appears to catch all the disks. my sql vms have about 7 or 9 or 11+ disks each.
a commanline example would be great.
im currently cloning a larger sql server to test this.
thanks
Mon May 18, 2020 3:31 am
Hi genelaoyan,
Welcome at StarWind Forum. Yes, V2V converter can convert a VM from ESXi to Hyper-V. Here is the guide https://www.starwindsoftware.com/v2v-he ... erver.html.
Here is more info about CLI https://www.starwindsoftware.com/v2v-he ... rface.html
genelaoyan
Tue May 19, 2020 2:34 am
given the below data can you post a sample commandline that would convert a vm on esx to hyper-v? i learn best by examples and should expidite my learning.
esx host: esx-prod1
user: root
password: rootpwd
vm name: yomama
bios/efi: bios
disks: 9 total (3 lsi sas & 6 paravirtual)
hyper-v proof of concept host: hypv-poc1
user: somecloud\hypvadmin
password: hyperfree
path: c:\clusterstorage\volume2\vms\
big thanks in advanced.
genelaoyan
Tue May 19, 2020 4:48 am
a good feature request would be a button a user can click to "script as" when in the gui after they configure a migration.
Wed May 20, 2020 10:48 am
Please, open a new call with StarWind support by filling this form https://www.starwindsoftware.com/support-form.
Use URL of this forum ticket as a reference.
