Sync Channels link with different bandwidth
jensleki
Sat Apr 18, 2020 1:32 pm
Can 2 sync link be configured with different bandwidths? For example a sync link of 25Gbps and another sync link at 10Gbps, or both should be links of the same bandwidth?
Sat Apr 18, 2020 5:18 pm
Hi jensleki,
You can use multiple synchronization connection. However, that would affect sync performance badly (you get the average performance of 2 links). This being said, I'd use links of the same bandwidth or 1 link of higher bandwidth.
