V2V Converter Issue
BigMac
Tue Mar 31, 2020 2:37 am
Hey All,
First of all i love the converter really good.
I'm converting VM's from VMware 6.5 to Hyper-V 2019 and it works fine.
The only issue i have is when the machines come over to Hyper-V they are in Generation 1, is there anyway to make the Generation 2 while converting?
Thanks.
Tue Mar 31, 2020 6:16 am
Hello, you can convert to 2nd gen. StarWind V2V automatically picks the VM generation. If the boot option is set to BIOS, the conversion is done to gen1 VM. If the boot option is set to UEFI, the converted VM will be of 2nd generation.
BigMac
Tue Mar 31, 2020 7:22 am
I only get the option to for Boot: BIOS i dont have the option to convert it to UEFI boot and i cannot change it.
Tue Mar 31, 2020 8:13 am
I see...
Unfortunately, StarWind V2V Converter picks generation automatically. There is no way to change it from GUI I guess.
Try this workaround https://docs.microsoft.com/en-us/archiv ... es-part-10.
Keep me posted!
davekeltner
Mon Apr 13, 2020 9:37 am
There is no way to change it from GUI.
Mon Apr 13, 2020 9:55 am
Dave,
Thanks for confirming.
