Unidentified error.
batiati
Sat Mar 14, 2020 12:46 am
Hi folks,
Yesterday (March 12, 2020) I had my first production issue using StarWind vSAN Free. I'm using vSAN servers (build 12767) on Hyper-V 2012 R2 FailoverCluster (2 storage and 3 computing servers separated)
All of sudden all my CSVs were paused, some VMs restarted and just one CSV have presented a Sync channel fail with a very bad iSCSI performance.
I could see this message several times on "events" tab of management console.
command "WRITE" ... request response time is longer than expected. Response time is 10 sec.
I have three CSV's, and of course it wouldn't be a network issue, because the other two stayed perfectly normal.
Here is a piece of the log file, this part repeats many times since the first time it happened.
3/11 23:25:26.934139 1458 Common: *** `anonymous-namespace'::iSCSIAsyncCommandCallback: User request 0000006F9A0EC9D0 has failed due to unidentified error.
3/11 23:25:26.934180 1458 func: >>> Async_Task_OpWrite_Partner_Failed::initialize
3/11 23:25:26.934206 1458 HA: Async_Task_OpWrite_Partner_Failed::initialize: params(partner_req = 0x0000006F9BB0B7B0) ENTERed
3/11 23:25:26.934220 1458 func: <<< Async_Task_OpWrite_Partner_Failed::initialize
3/11 23:25:26.934356 1174 func: >>> Async_Task_OpWrite_Partner_Failed::execute
3/11 23:25:26.934443 1458 Common: *** `anonymous-namespace'::iSCSIAsyncCommandCallback: User request 0000006F97C4BEB0 has failed due to unidentified error.
3/11 23:25:26.934470 1458 func: >>> Async_Task_OpWrite_Partner_Failed::initialize
3/11 23:25:26.934481 1458 HA: Async_Task_OpWrite_Partner_Failed::initialize: params(partner_req = 0x0000006F9BB0CEB0) ENTERed
3/11 23:25:26.934493 1458 func: <<< Async_Task_OpWrite_Partner_Failed::initialize
3/11 23:25:26.934610 7c0 func: >>> Async_Task_OpWrite_Partner_Failed::execute
3/11 23:25:26.936295 7c0 HA: Ssc_Request_Task::complete: Warning(Partner send): sscRequestTask(0000006F980298B0) partnerRequest(0000006F9BB0CEB0) GeneralOpCode(0x2A) ex(0x0), PartnerOpCode(0xF2), PartnerDiffTimeCompleteEXEC = 10000, ms DiffTimeCompleteINIT = 10000 ms, DiffTimeCompleteEXEC = 10000 ms. Target: 'iqn.2008-08.com.starwindsoftware:stg02.triadesolucoes.com.br-csv02'
3/11 23:25:26.936344 7c0 func: <<< Async_Task_OpWrite_Partner_Failed::execute
I tried to restart the StarWind service on one of nodes.
First it refused to restart, stayed stuck on "stopping" status. So I had to disable all Sync and iSCSI network interfaces to finally get it stopped.
After the restart, it did a Fast Sync and all normal again. I moved my machines back to this CSV and everyhing is ok now.
If you guys wanted more detailed logs, please let me know.
Michael (staff)
Sun Mar 15, 2020 1:17 pm
You are using outdated build. Please upgrade it to the latest one: https://www.starwindsoftware.com/release-notes-build
Steps to upgrade: https://knowledgebase.starwindsoftware. ... nd-version
batiati
Tue Mar 17, 2020 12:24 am
Thank you Michael
Do I need to request a new license in order to upgrade from build 12767 to the latest one?
Tue Mar 17, 2020 4:19 am
No, you do not need to request a new free key.
