Help
mahuan1688
Fri Feb 28, 2020 11:18 am
The server is in the cloud. Is there a good way to transfer the backup data to the local server!
Michael (staff)
Fri Feb 28, 2020 6:01 pm
Could you please clarify the question?
Also, please check StarWind v2v Converted help here (could be helpful): https://www.starwindsoftware.com/v2v-he ... chine.html
mahuan1688
Tue Mar 03, 2020 6:05 am
I mean I have two servers in the cloud, and the software in the cloud will automatically back up the database and other data. Do you have any good suggestions to transfer these backed up data to the machine designated by the office? Thank you
By the way, can the parameters of VTL tape library automatically transfer to the cloud be applied to the virtual disk, and the parameters of local and network are gray, with the attached figure
mahuan1688
Sun Mar 08, 2020 12:17 pm
Is anybody here/
Sun Mar 08, 2020 2:35 pm
Mahuan,
Sorry for the delayed reply. The answer will be provided tomorrow.
Mon Mar 09, 2020 12:30 pm
Sorry for the delayed response. This screenshot has been taken inside the Cloud Replicator, a piece of software that replicates tapes to the cloud.
In order to deploy VTL with local storage, use this guide, please: https://www.starwindsoftware.com/resour ... l-storage/.
mahuan1688
Mon Mar 09, 2020 2:08 pm
1.The part circled in red can't be selected. Will it support saving to local or network or FTP server in the future!!
2.I have two servers in the cloud, and the software in the cloud will automatically back up the database and other data. Do you have any good suggestions to transfer these backed up data to the machine designated by the office? Thank you
The backup software does not support VTL. Is there a good solution to starwind
Mon Mar 09, 2020 2:52 pm
Correct me if I'm wrong.
You are running production in the cloud and back up your environment to the same cloud. That does not fulfill the 3-2-1 backup rule https://www.starwindsoftware.com/blog/3 ... s-survives.
If that's the case, we cannot help you as your backup software does not support VTL. Please check this guide https://www.starwindsoftware.com/resour ... l-storage/; we cannot help you with our solutions.
