wich node to choose as resync source after HA sync fail
Info@ipsafe.de
Thu Feb 27, 2020 10:35 am
wich node to choose as resync source after HA syncronisation failure , if you do not know wich one has the newer data ?
mfg
norman
VMax (staff)
Thu Feb 27, 2020 11:34 am
To determine which node has the latest data, you have to look at Windows application logs. There, in events related to StarWind, you should find which node went to not synchronized state the last.
In case it is not possible for you, there is another way of checking the data manually. To do that, you have to stop and disable StarWind service on one of the nodes, and maybe even disable sync channel just to make sure sync won't start. After that you can mark another node with active service as Synchronized and check if info there is what you need. If it is not, you have to stop and disable StarWind service on it, and check the other node the same way. When the node with needed data is active you just need to start StarWind sevice on the other node and sync will start.
Let us know if something is still unclear for you about this process.
Info@ipsafe.de
Thu Feb 27, 2020 11:53 am
ok - thank you
Thu Feb 27, 2020 12:26 pm
You are always welcome.
