Problem adding Whitness node - EVAL
vebjornn
Sun Feb 09, 2020 5:34 pm
Hello.
I'm evaluating the product, and have problem by adding a Whitness node.
I'v using the Starwind Virtual SAN for vSphere 2-node HCI Scenario with vSphere 6.5 and Linux virtual machine.
I'v managed to set up two Starwind virtual machines, added device and added a partner. Selected the "Node Majority" failover strategy.
Then, when I'm adding a Withness: "Right-click on the HA device with the configured Node Majority failover policy and select Replication Manager and press the Add Replica button"
The "Add replica button is grey"!!
https://www.starwindsoftware.com/resour ... 3c6048e72d
My trial license is for two servers
vebjornn
Mon Feb 10, 2020 8:01 pm
Hello again.
I recived a new trial licence and the problem is solved.
It was restrictions in my first license - for only two hosts. So the withness also counts as a host.
/Vebjorn
Oleg(staff)
Mon Feb 10, 2020 9:06 pm
Hello Vebjorn,
Yes, you need a different StarWind license for Node Majority configuration, for three nodes.
Thank you for the update.
asherxo
Mon Aug 24, 2020 10:17 am
Hey, can you please update the post and is it going good on your side? Cause I'm planning to get a trial too.
Mon Aug 24, 2020 10:34 am
Are you planning to use node majority failover strategy?
