AndyCanty
Thu Jan 30, 2020 9:32 am
Been looking at the example powershell script and there is no provision to create a tape with a custom barcode.
Is there one?
What i'm trying to do is quickly create multiple tapes with a specific prefix to make searching in Azure quicker and more intuitive.
Each tape job in Veeam, would have its own tape pool to draw from.
I appreciate this creates a small over head for us.
Unless you can suggest another better way?
Thanks in advance
Andy.
AndyCanty
AndyCanty
Tue Oct 20, 2020 1:30 pm
Just to finish off this thread, and say thank you to the team, they worked with what i asked them and incorporated it into the latest version of Starwind VTL - testing was delayed due to covid.
I can confirm the ability to add custom tape Barcodes using the separate powershell script.
Thanks chaps
peterrolf
Thu Oct 20, 2022 6:15 pm
Hello, can you post the script to the forum? I have a similar requirement and would like to use the script as a staring point. Thanks, Peter
Thu Oct 20, 2022 9:04 pm
Hi Peter,
Welcome to StarWind Forum! The script should be already in the latest revision of StarWindX. Check it out. Let me know if additional assistance is needed.
peterrolf
