V2V VMware to HyperV
capakito
Thu Jan 23, 2020 2:28 pm
hello, i am planinng to use V2V converter and i have a question.
i need to convert VMware VM to HyperV. The VM has more than one disk, so my question is if i can convert the VM with the attached disk? Or i have to convert every disk separately?
thank you
Thu Jan 23, 2020 3:05 pm
Greetings,
You can convert the VM together with all its disks in one go.
capakito
Fri Jan 24, 2020 8:11 am
Thank you first of all. After the conversation process will be created one VHD(X) or as many as i had on VMware?
Fri Jan 24, 2020 8:38 am
It is a pleasure to help you.
There will be as many VHD(X) drives as you had on ESXi VM.
capakito
Fri Jan 24, 2020 8:54 am
Thank you Yaroslav for info!
Fri Jan 24, 2020 9:22 am
You are always welcome.
capakito
Fri Jan 24, 2020 9:59 am
After successfully connection with StarWind from Hyperv(where is installed the converter) to Esxi, i am getting the error
ERROR OPENING IMAGE
THE SERVER REFUSED CONNECTION.
The VM is powered off.
Any suggestions...
Fri Jan 24, 2020 10:31 am
Did you login with root credentials?
Can the target server accept remote connections?
Did you get to the stage of VM selection?
capakito
Fri Jan 24, 2020 10:58 am
Problem resolved. there was network restrictions.
thank you
Fri Jan 24, 2020 11:13 am
Happy to know that everything works as it should now. Should you have any questions, I am here to help.
