Is delta syncing possible?
georgeparker
Tue Jan 14, 2020 5:49 am
Hi, I'm new to Starwind V2V Converter, but I've used VMware Converter lots of times. VMware Converter has a feature where after performing the initial full sync of the source VM or physical server to the target vSphere environment, I can perform as many incremental/delta syncs as I want until it comes time to do the final sync/cuttover. Each incremental/delta sync doesn't take nearly as long to complete as the initial full sync. Can Starwind V2V Converter also do this?
George.
Tue Jan 14, 2020 9:41 am
Hi George,
Unfortunately, StarWind cannot create deltas while converting a VM. StarWind V2V Converter can convert a VM only if it is powered off.
georgeparker
Tue Jan 14, 2020 10:22 pm
Ah ok, thanks for your prompt reply.
Regards, George.
Wed Jan 15, 2020 7:57 am
Always happy to help you.
