Add a new ISCSI target with current VirtualSUN Free Licence?
jmar83
Tue Nov 26, 2019 4:49 pm
Hi there
How to add a new ISCSI target with current VirtualSUN Free Licence? (Under free licence, the GUI does not seems to support that action, i think i'm right?) I can't find any documentation related to that issue..
thx for feedback.
With best regards from Switzerland
Jan
Wed Nov 27, 2019 7:52 am
Jan,
You would need to adjust an example script from the StarWindX Powershell samples folder in your StarWind installation path. There is a script called CreateHA*.ps1. Just select your scenario and adjust the parameters as needed.
