Getting the list of the tapes in the Offline Shelf
cforest
Wed Oct 23, 2019 5:10 pm
Hi there,
Just wanted to ask if there is any way to get the lists of the tapes in the Offline Shelf for a given VTL device via StarWindX with PowerShell? We need it to automate inserting a tape back to the drive/slot when we don't know the names of the such tapes in advance. To automate it, we already have two piece of codes:
1. InsertVirtualTape.ps1 in your Samples - it is a good example of how to insert a tape when you know its name
2. A code to get a free slot:
foreach ($slot in $device.Slots) {
        if (($slot.Barcode -eq '') -and (($slot.SlotName -match 'TapeDrive') -or ($slot.SlotName -match 'Storage'))) {
            $freeSlot = $slot.slotAddress;
            "Slot: " + $slot.SlotName
            break;
The only thing we don't know is how to get the list of the tapes in the Offline Shelf. Is there any way to get it with PowerShell?
Version 8.0.0.13182
Wed Oct 23, 2019 6:42 pm
You might want to check:
$server.Devices[0].Tapes
for the property called SlotType.
For a tape in any slot it would return "Storage", while for offline tapes it is "Unknown".
Sample output:
PS C:\Program Files\StarWind Software\StarWind\StarWindX\Samples\powershell> $server.Devices[0].Tapes
Barcode   : SWCJJ003
SlotType  : Storage
TapeType  : U-832
UsedSpace : 0
Barcode   : SWCJJ006
SlotType  : Storage
TapeType  : U-832
UsedSpace : 0
Barcode   : SWCJJ007
SlotType  : Storage
TapeType  : U-832
UsedSpace : 0
Barcode   : SWCJJ008
SlotType  : Storage
TapeType  : U-832
UsedSpace : 0
Barcode   : SWCJJ009
SlotType  : Storage
TapeType  : U-832
UsedSpace : 0
Barcode   : SWCJJ00A
SlotType  : Storage
TapeType  : U-832
UsedSpace : 0
Barcode   : SWCJJ00B
SlotType  : Storage
TapeType  : U-832
UsedSpace : 0
Barcode   : SWCJJ00C
SlotType  : Storage
TapeType  : U-832
UsedSpace : 0
Barcode   : SWCJJ00D
SlotType  : Storage
TapeType  : U-832
UsedSpace : 0
Barcode   : SWCJJ00E
SlotType  : Storage
TapeType  : U-832
UsedSpace : 0
Barcode   : SWCJJ00F
SlotType  : Storage
TapeType  : U-832
UsedSpace : 0
Barcode   : SWCJJ00G
SlotType  : Storage
TapeType  : U-832
UsedSpace : 0
Barcode   : SWCJJ00H
SlotType  : Storage
TapeType  : U-832
UsedSpace : 0
Barcode   : SWCJJ004
SlotType  : Unknown
TapeType  :
UsedSpace : 0
Barcode   : SWCJJ005
SlotType  : Unknown
TapeType  :
UsedSpace : 0
Screen Shot 2019-10-23 at 21.41.30.png (42.06 KiB) Viewed 52971 times
cforest
Thu Oct 24, 2019 4:56 pm
Thank you!
It seems to work. The only thing I changed was using both SlotType and TapeType, because I observed "Unknown" for tapes in the Offline Shelf and the tapes in Drives.
if (($tape.SlotType -match 'Unknown') -and ($tape.TapeType -eq '')) {
Offline Tape: SWPKU001
Offline Tape: SWPKU004
Offline Tape: SWPKU00A
Drive1: SWPKU003
Drive2: SWPKU009
Barcode : SWPKU003
SlotType : Unknown
TapeType : U-832
UsedSpace : 0
Barcode : SWPKU009
SlotType : Unknown
TapeType : U-832
UsedSpace : 0
Barcode : SWPKU008
SlotType : Storage
TapeType : U-832
UsedSpace : 0
Barcode : SWPKU005
SlotType : Storage
TapeType : U-832
UsedSpace : 0
Barcode : SWPKU007
SlotType : Storage
TapeType : U-832
UsedSpace : 0
Barcode : SWPKU006
SlotType : Storage
TapeType : U-832
UsedSpace : 0
Barcode : SWPKU002
SlotType : Storage
TapeType : U-832
UsedSpace : 0
Barcode : SWPKU001
SlotType : Unknown
TapeType :
UsedSpace : 0
Barcode : SWPKU004
SlotType : Unknown
TapeType :
UsedSpace : 0
Barcode : SWPKU00A
SlotType : Unknown
TapeType :
UsedSpace : 0
Fri Oct 25, 2019 9:26 am
Totally makes sense. I missed it, so thanks for pointing it out.
Glad it worked for you.
