Ralf
Tue Oct 15, 2019 8:24 am
Hi all,
i have to convert a VM from the DMZ to the internal network.
The security guys asks me which ports they have to open?
Is anywhere a list of all ports which the converter needs?
regards
Ralf
Ralf
Ralf
Mon Oct 28, 2019 10:18 am
HI,
on the FW the ports are open now but i get an error.
I can select the VM on ESX host from my Hyper-v host.
But if the convertion start the VM on hyper-v was created but the disk was not created.
Any idea?
regards
Ralf
The log file name: 'logs\V2V_Log-20191028-110652.log' (PID 13756)
Delete log file 'logs\V2V_Log-20191028-085951.log'.
10/28 11:06:52.019 2de8 Facility ???INFO: CV2V_ConverterApp::InitInstance: SetDllDirectory: C:\Program Files\StarWind Software\StarWind V2V Image Converter\lib
10/28 11:06:52.035 2de8 Facility ???INFO: CV2V_ConverterApp::InitInstance: Load language IDR_XML_ENGLISH
10/28 11:06:52.035 2de8 Facility ???INFO: CV2V_ConverterApp::InitInstance: Load language IDR_XML_RUSSIAN
10/28 11:06:52.035 2de8 Facility ???INFO: CV2V_ConverterApp::InitInstance: Set current language English
10/28 11:06:52.035 2de8 Facility ???INFO: CPS_V2V_Converter::CPS_V2V_Converter: Version MajorVersion 6, MinorVersion 3, BuildNumber 9600
10/28 11:06:52.050 2de8 Facility ???INFO: WrapperHyperV::WrapperHyperV: LoadLibrary C:\Windows\system32\wbem\wmiutils.dll - 2fd80000
10/28 11:06:56.519 2de8 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eESXConnection
10/28 11:07:17.144 2de8 Facility ???INFO: WrapperESXI::connect: m_url - [ ... ]
10/28 11:07:17.222 2de8 Facility ???INFO: WrapperESXI::connect: fullName - Administrator, key - 703b6e90-893c-1094-6f48-3e9c509c70ed
10/28 11:07:17.222 2de8 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eInputVM
10/28 11:07:17.316 2de8 Facility ???INFO: VMConverter::ESXIConverter::GetHostListInfo: ESX version: 5.5.0
10/28 11:07:28.238 2de8 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eLocationTo
10/28 11:07:30.425 2de8 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eHYPERVConnectionTo
10/28 11:07:31.503 2de8 Facility ???INFO: WrapperHyperV::connect: Host - \\localhost\root\virtualization\v2
10/28 11:07:31.550 2de8 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eVMSettings
10/28 11:07:40.082 2de8 Facility ???INFO: VMConverter::HyperVConverter::GetHostListInfo: HyperV version: 6.3.9600
10/28 11:07:40.082 2de8 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eConverting
10/28 11:07:40.097 3670 Facility ???INFO: CPPConverting::Convert: InConvertType: 6, OutConvertType: 8
10/28 11:07:40.644 3670 Facility ???INFO: WrapperHyperV::getMaxMemory: MaxRAM - 511224
10/28 11:07:40.925 3670 Facility ???INFO: CPPConverting::ConverterHyperV: Create VM 614DFCFC-9A8B-4977-9D58-2D7348010484
10/28 11:07:41.003 3670 Facility ???INFO: CPPConverting::ConvertImage: pathInput: [xxxxxxxx-02] Thomas-Test/Thomas-Test.vmdk, pathOutput: C:\ClusterStorage\Volume10\Thomas-Test\Virtual Hard Disks\Thomas-Test.vhdx
10/28 11:07:41.175 3670 Facility ???INFO: ESXVmdk::ParseFile: sFilename - [xxxxxxxx-02] Thomas-Test/Thomas-Test.vmdk
10/28 11:07:41.175 3670 Facility ???INFO: ESXVmdk::ParseFile: m_cSSLThumbprint - EA:F2:C3:F3:17:11:14:DD:47:91:84:2C:55:53:67:44:B2:55:BD:5C
10/28 11:07:41.175 3670 Facility ???INFO: ESXVmdk::ParseFile: m_cvmxSpec - [klnvmvh04-02] Thomas-Test/Thomas-Test.vmx
10/28 11:08:24.550 3670 Facility ???ERROR: ESXVmdk::ParseFile: m_VixDiskLib_Open is fail - 14009, The server refused connection
10/28 11:08:24.550 3670 Facility ???ERROR: ESXIDisk::CreateInputImage: ParseFile is fail
10/28 11:08:24.550 3670 Facility ???INFO: CPPConverting::ConvertImage: CreateInputImage: 1
10/28 11:08:24.550 3670 Facility ???ERROR: CPPConverting::Convert: FAILED
Ralf
Mon Oct 28, 2019 11:10 am
Hi Boris,
it is ESX Version 5.5 commercial .
At the internal network it works without problems.
Now i try it from the DMZ (ESX) to the internal (Hyper-v).
I open the ports which you told me before.
TCP ports 443 and 80. For Hyper-V, it uses WMI to connect to the hosts.
WMI ports 49152 und 65535.
Mon Oct 28, 2019 11:28 am
It looks like you have not opened TCP 135, which is required for WMI.
WMI uses dynamic ports
between these two ports. You can set its port to use a static one, if you need to keep it open.
Ralf
Tue Nov 05, 2019 9:04 am
Hi, 135 was open. I checked the connection with the security guys..... 902 was missing. Now it works
Thu Jun 11, 2020 12:43 pm
Ralf wrote:HI,
Any idea?
regards
Ralf
