StarWIND vvol
sayyed.aleem
Tue Aug 20, 2019 2:04 am
Hi Community,
I am coming an across issue when setting up an VVOL HA Datastore cluster in the test environment. I have two StarWind VMs running on Windows Server 2016. When running the following command to create a cluster, I came across the following. StarWIND VMs are running on VMWare Workstation Pro 15x. Each VM has two thin-provisioned VMDK files.
Any ideas
Cheers
Oleg(staff)
Tue Aug 20, 2019 9:05 am
What StarWind build are you using?
sayyed.aleem
Wed Aug 21, 2019 1:04 pm
I am using following version;
Wed Aug 21, 2019 4:57 pm
Did you make sure to include Cluster Service as part of your StarWind VSAN installation?
sayyed.aleem
Thu Aug 22, 2019 5:42 am
I selected full installation during the wizard.
After installation, StarWind Cluster service does not start despite the fact that it is set to Automatic, and generates following error when started manually;
The StarWind Cluster Service service failed to start due to the following error:
The service did not respond to the start or control request in a timely fashion.
The StarWind NVMe over Fabrics Target service terminated unexpectedly. It has done this 2 time(s).
Oleg(staff)
Fri Aug 23, 2019 6:07 pm
We have some issues with VVoLs work with the current StarWind build.
The issue should be fixed with the next StarWind release:
https://www.starwindsoftware.com/release-notes-build
