Load from Offline Shelf
willn333
Tue Aug 06, 2019 2:47 am
I am running the free version of VTL and using powershell for management, but I cannot find any documentation or anything on how to load a tape from the offline shelf to a slot.
When I do a listing of slots with the provided script, the offline shelf doesn't show up.
I also have a tape in the offline shelf I would like to delete, but it is the same issue, I have no visibility to the offline shelf via powershell.
Tue Aug 06, 2019 11:40 pm
If you need to get the list of tapes in the offline shelf, you can check for the following:
$tape.SlotType -eq "unknown"
It will give you the list of tapes there.
To insert any such tape, you would run a script based on the InsertVirtualTape.ps1 script that shows how to load a virtual tape into a slot. It's just about checking which slots are free (no barcode is displayed for free slots) and deciding which one to use.
willn333
Wed Aug 07, 2019 1:57 am
Boris (staff) wrote:If you need to get the list of tapes in the offline shelf, you can check for the following:
This actually doesn't work for me. If I check the tapes in the library with:
	foreach($tape in $device.Tapes)
		write-host "Tape:"
		$tape
I do not get any tapes that are in the offline shelf. The question here would be how do you populate the variable for $tape? If I use a string, it doesn't come back with anything. If I list all the slottypes with:
foreach($slot in $device.Slots)
		write-host "Slot:"
		$slot
I get transport, import/export, storage, and drive. There is no "unknown" type.
Would you be able to provide a little more information?
Wed Aug 07, 2019 6:58 pm
If you are sure you've got an offline tape in the system (e.g. you see it via StarWind Management Console) try checking for those using something like:
		if($tape.SlotType -eq "unknown"){
            write-host "Tape:"
		    $tape
This will give you the list of offline tapes, where $tape is an object with its properties. You can check the script I mentioned before for how the $tape variable is populated.
With slots it's also not really complicated:
$deviceName = "VTL1"
foreach($slot in $device.Slots) {
	write-host "Slot:"
	$slot
willn333
Thu Aug 08, 2019 12:09 am
Boris (staff) wrote:If you are sure you've got an offline tape in the system (e.g. you see it via StarWind Management Console) try checking for those using something like:
            write-host "Tape:"
		    $tape
	write-host "Slot:"
	$slot
This does not work for me. I don't know if I am missing something. Here is my output:
PS C:\Program Files\StarWind Software\StarWind\StarWindX\Samples\powershell> foreach($tape in $device.Tapes)
            write-host "Tape:"
          $tape
As you can see from this output, I have one tape and it is the online one.
PS C:\Program Files\StarWind Software\StarWind\StarWindX\Samples\powershell> $device.tapes
Barcode   : SWECE002
SlotType  : Storage
TapeType  : U-832
UsedSpace : 0
Also, I am attaching the output of $device.slots below:
Barcode                                                    SlotType                                                   SlotName        slotAddress
                                                           Transport                                                  Transport 1        0
                                                           Drive                                                      TapeDrive 1        1
                                                           Drive                                                      TapeDrive 2        2
                                                           Drive                                                      TapeDrive 3        3
                                                           Drive                                                      TapeDrive 4        4
                                                           Import/Export                                              ImpExp 1        101
                                                           Import/Export                                              ImpExp 2        102
                                                           Import/Export                                              ImpExp 3        103
                                                           Storage                                                    Storage 01        1001
SWECE002                                                   Storage                                                    Storage 02        1002
                                                           Storage                                                    Storage 03        1003
                                                           Storage                                                    Storage 04        1004
                                                           Storage                                                    Storage 05        1005
                                                           Storage                                                    Storage 06        1006
                                                           Storage                                                    Storage 07        1007
                                                           Storage                                                    Storage 08        1008
                                                           Storage                                                    Storage 09        1009
                                                           Storage                                                    Storage 10        1010
                                                           Storage                                                    Storage 11        1011
                                                           Storage                                                    Storage 12        1012
                                                           Storage                                                    Storage 13        1013
                                                           Storage                                                    Storage 14        1014
                                                           Storage                                                    Storage 15        1015
                                                           Storage                                                    Storage 16        1016
                                                           Storage                                                    Storage 17        1017
                                                           Storage                                                    Storage 18        1018
                                                           Storage                                                    Storage 19        1019
                                                           Storage                                                    Storage 20        1020
                                                           Storage                                                    Storage 21        1021
                                                           Storage                                                    Storage 22        1022
                                                           Storage                                                    Storage 23        1023
                                                           Storage                                                    Storage 24        1024
                                                           Storage                                                    Storage 25        1025
                                                           Storage                                                    Storage 26        1026
                                                           Storage                                                    Storage 27        1027
                                                           Storage                                                    Storage 28        1028
                                                           Storage                                                    Storage 29        1029
                                                           Storage                                                    Storage 30        1030
                                                           Storage                                                    Storage 31        1031
                                                           Storage                                                    Storage 32        1032
                                                           Storage                                                    Storage 33        1033
                                                           Storage                                                    Storage 34        1034
                                                           Storage                                                    Storage 35        1035
                                                           Storage                                                    Storage 36        1036
                                                           Storage                                                    Storage 37        1037
                                                           Storage                                                    Storage 38        1038
                                                           Storage                                                    Storage 39        1039
                                                           Storage                                                    Storage 40        1040
                                                           Storage                                                    Storage 41        1041
                                                           Storage                                                    Storage 42        1042
                                                           Storage                                                    Storage 43        1043
                                                           Storage                                                    Storage 44        1044
                                                           Storage                                                    Storage 45        1045
                                                           Storage                                                    Storage 46        1046
                                                           Storage                                                    Storage 47        1047
                                                           Storage                                                    Storage 48        1048
                                                           Storage                                                    Storage 49        1049
                                                           Storage                                                    Storage 50        1050
                                                           Storage                                                    Storage 51        1051
                                                           Storage                                                    Storage 52        1052
                                                           Storage                                                    Storage 53        1053
                                                           Storage                                                    Storage 54        1054
                                                           Storage                                                    Storage 55        1055
                                                           Storage                                                    Storage 56        1056
                                                           Storage                                                    Storage 57        1057
                                                           Storage                                                    Storage 58        1058
                                                           Storage                                                    Storage 59        1059
                                                           Storage                                                    Storage 60        1060
                                                           Storage                                                    Storage 61        1061
                                                           Storage                                                    Storage 62        1062
                                                           Storage                                                    Storage 63        1063
                                                           Storage                                                    Storage 64        1064
                                                           Storage                                                    Storage 65        1065
                                                           Storage                                                    Storage 66        1066
                                                           Storage                                                    Storage 67        1067
                                                           Storage                                                    Storage 68        1068
                                                           Storage                                                    Storage 69        1069
                                                           Storage                                                    Storage 70        1070
                                                           Storage                                                    Storage 71        1071
                                                           Storage                                                    Storage 72        1072
                                                           Storage                                                    Storage 73        1073
                                                           Storage                                                    Storage 74        1074
                                                           Storage                                                    Storage 75        1075
                                                           Storage                                                    Storage 76        1076
                                                           Storage                                                    Storage 77        1077
                                                           Storage                                                    Storage 78        1078
                                                           Storage                                                    Storage 79        1079
                                                           Storage                                                    Storage 80        1080
                                                           Storage                                                    Storage 81        1081
                                                           Storage                                                    Storage 82        1082
                                                           Storage                                                    Storage 83        1083
                                                           Storage                                                    Storage 84        1084
                                                           Storage                                                    Storage 85        1085
                                                           Storage                                                    Storage 86        1086
                                                           Storage                                                    Storage 87        1087
                                                           Storage                                                    Storage 88        1088
                                                           Storage                                                    Storage 89        1089
                                                           Storage                                                    Storage 90        1090
                                                           Storage                                                    Storage 91        1091
                                                           Storage                                                    Storage 92        1092
                                                           Storage                                                    Storage 93        1093
                                                           Storage                                                    Storage 94        1094
                                                           Storage                                                    Storage 95        1095
                                                           Storage                                                    Storage 96        1096
Next, to validate we are looking at the right device:
DeviceType             : VTL
DeviceId               : 0x0000004F31926E40
File                   :
TargetName             : iqn.2008-08.com.starwindsoftware:veeambackup-targetvtl1
TargetId               : 0x0000004F3034F180
CacheMode              : empty
CacheSize              : empty
CacheBlockExpiryPeriod : empty
Exists                 : True
DeviceLUN              : 0
IsSnapshotsSupported   : False
Snapshots              :
SectorSize             :
State                  : 0
Tapes                  : System.__ComObject
AvailableSlots         : 95
TransportSlots         : 1
DriveSlots             : 4
ImportExportSlots      : 3
StorageSlots           : 96
Slots                  : System.__ComObject
ReplicationSettings    : System.__ComObject
DriveType              : 8
Lastly, so you can see the tapes are available in the offline shelf, I have attached a screenshot of the management console.
Maybe the issue is because they are still in the uploading phase? If that is the case, what if I wanted to stop the upload and delete them anyways?
Also, how would I remove that one that it couldn't find, SWV2401L?
Thu Aug 08, 2019 11:04 am
The issue is that you just take some small part of a PowerShell script and want it to work as if it were a separate script. It does not work like that. The suggested changes I posted needed to be implemented into a script of yours, where you would connect to your StarWind server, get the list of the devices there, identify the tape device and query its status and the tapes it has got.
willn333
Thu Aug 08, 2019 4:40 pm
Not the first time I have used powershell, so I understand how it works. I was doing the connection and just giving you snippets to show you what it would return, but, OK, let's follow down your path. Here is my script and the output.
Let me know if there is something I am missing.
Script:
Import-Module StarWindX
try
	Enable-SWXLog
    $server.Connect()
	$deviceName = "vtl1"
    $device
	if( !$device )
		Write-Host "Device '$($deviceName)' not found" -foreground red
		return
   write-host "Slot:"
   $slot
            write-host "Tape:"
          $tape
catch
    Write-Host $_ -foreground red
finally
	$server.Disconnect()
Output:
DeviceType             : VTL
DeviceId               : 0x000000DDC6E280C0
File                   :
TargetId               : 0x000000DDC69BFF40
CacheMode              : empty
CacheSize              : empty
Exists                 : True
DeviceLUN              : 0
Snapshots              :
SectorSize             :
State                  : 0
AvailableSlots         : 96
TransportSlots         : 1
DriveSlots             : 4
StorageSlots           : 96
DriveType              : 8
Slot:
Barcode     :
SlotType    : Transport
SlotName    : Transport 1
slotAddress : 0
Slot:
Barcode     :
SlotType    : Drive
SlotName    : TapeDrive 1
slotAddress : 1
Slot:
Barcode     :
SlotType    : Drive
SlotName    : TapeDrive 2
slotAddress : 2
Slot:
Barcode     :
SlotType    : Drive
SlotName    : TapeDrive 3
slotAddress : 3
Slot:
Barcode     :
SlotType    : Drive
SlotName    : TapeDrive 4
slotAddress : 4
Slot:
Barcode     :
SlotType    : Import/Export
SlotName    : ImpExp 1
slotAddress : 101
Slot:
Barcode     :
SlotName    : ImpExp 2
slotAddress : 102
Slot:
Barcode     :
SlotName    : ImpExp 3
slotAddress : 103
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 01
slotAddress : 1001
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 02
slotAddress : 1002
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 03
slotAddress : 1003
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 04
slotAddress : 1004
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 05
slotAddress : 1005
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 06
slotAddress : 1006
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 07
slotAddress : 1007
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 08
slotAddress : 1008
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 09
slotAddress : 1009
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 10
slotAddress : 1010
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 11
slotAddress : 1011
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 12
slotAddress : 1012
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 13
slotAddress : 1013
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 14
slotAddress : 1014
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 15
slotAddress : 1015
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 16
slotAddress : 1016
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 17
slotAddress : 1017
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 18
slotAddress : 1018
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 19
slotAddress : 1019
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 20
slotAddress : 1020
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 21
slotAddress : 1021
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 22
slotAddress : 1022
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 23
slotAddress : 1023
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 24
slotAddress : 1024
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 25
slotAddress : 1025
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 26
slotAddress : 1026
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 27
slotAddress : 1027
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 28
slotAddress : 1028
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 29
slotAddress : 1029
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 30
slotAddress : 1030
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 31
slotAddress : 1031
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 32
slotAddress : 1032
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 33
slotAddress : 1033
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 34
slotAddress : 1034
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 35
slotAddress : 1035
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 36
slotAddress : 1036
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 37
slotAddress : 1037
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 38
slotAddress : 1038
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 39
slotAddress : 1039
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 40
slotAddress : 1040
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 41
slotAddress : 1041
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 42
slotAddress : 1042
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 43
slotAddress : 1043
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 44
slotAddress : 1044
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 45
slotAddress : 1045
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 46
slotAddress : 1046
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 47
slotAddress : 1047
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 48
slotAddress : 1048
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 49
slotAddress : 1049
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 50
slotAddress : 1050
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 51
slotAddress : 1051
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 52
slotAddress : 1052
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 53
slotAddress : 1053
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 54
slotAddress : 1054
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 55
slotAddress : 1055
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 56
slotAddress : 1056
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 57
slotAddress : 1057
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 58
slotAddress : 1058
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 59
slotAddress : 1059
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 60
slotAddress : 1060
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 61
slotAddress : 1061
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 62
slotAddress : 1062
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 63
slotAddress : 1063
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 64
slotAddress : 1064
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 65
slotAddress : 1065
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 66
slotAddress : 1066
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 67
slotAddress : 1067
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 68
slotAddress : 1068
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 69
slotAddress : 1069
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 70
slotAddress : 1070
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 71
slotAddress : 1071
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 72
slotAddress : 1072
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 73
slotAddress : 1073
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 74
slotAddress : 1074
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 75
slotAddress : 1075
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 76
slotAddress : 1076
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 77
slotAddress : 1077
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 78
slotAddress : 1078
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 79
slotAddress : 1079
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 80
slotAddress : 1080
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 81
slotAddress : 1081
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 82
slotAddress : 1082
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 83
slotAddress : 1083
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 84
slotAddress : 1084
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 85
slotAddress : 1085
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 86
slotAddress : 1086
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 87
slotAddress : 1087
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 88
slotAddress : 1088
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 89
slotAddress : 1089
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 90
slotAddress : 1090
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 91
slotAddress : 1091
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 92
slotAddress : 1092
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 93
slotAddress : 1093
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 94
slotAddress : 1094
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 95
slotAddress : 1095
Slot:
Barcode     :
SlotType    : Storage
SlotName    : Storage 96
slotAddress : 1096
As you can see, I have your exact code in the script and it returns nothing.
Wed Sep 18, 2019 2:10 pm
Could you submit a support request addressing me and referring this thread? I would like to have a closer look at your case.
