Service keeps crashing
jamesh
Sat May 11, 2019 12:23 am
I'm sorry if this has been posted before but I couldn't find a solution to my issue.
We've been using StarWind VTL solution for a few weeks with no issues. Recently it stopped working properly with nothing changing on the server, but now we have a StarWind service that will not stay started. In the event viewer, I have the below message any time we try to start the service. Any direction would be greatly appreciated. Thank you
Faulting application name: StarWindNVMeoF.exe, version: 1.1.0.1030, time stamp: 0x5ba4f571
Faulting module name: StarWindNVMeoF.exe, version: 1.1.0.1030, time stamp: 0x5ba4f571
Exception code: 0xc0000005
Fault offset: 0x000000000001c3a7
Faulting process id: 0x9cc
Faulting application start time: 0x01d5078ec8737549
Faulting application path: E:\Program Files\StarWind Software\StarWind\StarWindNVMeoF.exe
Faulting module path: E:\Program Files\StarWind Software\StarWind\StarWindNVMeoF.exe
Report Id: 78009b60-c6c5-4d56-8af7-e4471481ac56
Faulting package full name:
Faulting package-relative application ID:
Sun May 12, 2019 4:58 am
It's designed for NVMe-over-Fabrics targets. It is safe to disable it in your environment.
jamesh
Mon May 13, 2019 5:52 pm
Okay, thank you for that information I went ahead and disabled that service since it's not needed.
I believe then there might be an issue with the license key I received. I only needed the VTL license so I could enable doing long term storage to disk. When I take the license provided to me after I connect to the server I have starwind's installed on I can no longer add a VTL Device. If I add the trial license back on the machine I'm able to add the device. Should I be reaching back out to the group that provided me with the free VTL license?
Mon May 13, 2019 10:56 pm
With the free license, you can only use your StarWind management console in read-only mode, i.e. for monitoring. You would need to use the StarWindX PowerShell module to operate the server, e.g. create devices and more.
