Missing files upon installation of VSAN Free
alexandru.luca
Tue Apr 02, 2019 9:53 pm
Hello community,
Trying to install Starwind VSAN free edition on a Windows Server 2012 R2 and I get confronted right at the beggining with the following error:
api-ms-win-crt-runtime-l1-1-0.dll is missing...
then at the end of the installation with:
api-ms-win-crt-stdio-l1-1-0.dll is missing &
api-ms-win-crt-filesystem-l1-1-0.dll is missing
I have attached screenshots with the above errors.
Already tried to install visual c++ x64 but this didn’t resolved the issue. Anyone seen this happen before?
Maybe someone can provide me with a solution to the above problem. I already searched the forum and didn’t found anything related.
Thank you!
A Luca
Wed Apr 03, 2019 1:54 pm
Do you need the CloudReplicator functionality? Uncheck it in the corresponding option in the components list and it should be fine.
alexandru.luca
Wed Apr 03, 2019 3:53 pm
I don’t need that but what about Starwind SMI-S agent? What’s its functionality? I only need to configure a cluster of two windows server 2012 r2 bare metal servers that will run hyper-v VMs.
Wed Apr 03, 2019 4:12 pm
The StarWind SMI-S agent is required to be able to create StarWind virtual disks from Microsoft SCVMM. Check this for more details https://www.starwindsoftware.com/resour ... nager-2016
