Powershell cmdlets: running a script remotely
cforest
Fri Jan 11, 2019 2:35 pm
Hi there,
Just wanted to ask if it is somehow possible to use StarWindX cmdlets while running a PowerShell script on a remote computer. Here is my code:
param (
    $tapeLibMachine
$mycreds = ConvertTo-SecureString "MyPassword" -AsPlainText -Force | % {New-Object System.Management.Automation.PSCredential ("$tapeLibMachine\Administrator", $_)}
$scriptBlock = {
    try {
        Import-Module StarWindX
        Enable-SWXLog
        $server.Connect()
    catch {
        $errDescription = $Error[0].Exception.Message
        "Error occured: $errDescription"
    finally {
        $server.Disconnect()
Invoke-Command -Computername $tapeLibMachine -Credential $mycreds -ScriptBlock $scriptBlock
Here is the output:
C:\Scripts\>powershell .\test.ps1 avo-vtl
StarWindX doesn't support current appartment. You need to run this script with -STA switch to use StarWindX.
At C:\Scripts\test.ps1:32 char:1
+ Invoke-Command -Computername $tapeLibMachine -Credential $mycreds -ScriptBlock $ ...
    + CategoryInfo          : OperationStopped: (StarWindX doesn... use StarWindX.:String) [], RuntimeException
    + FullyQualifiedErrorId : StarWindX doesn't support current appartment. You need to run this script with -STA switch to use StarWindX.
I am able to use StarWindX cmdlets locally and fail to understand what I miss when using them remotely. On both remote and local machines, Powershell 4 is installed, and STA mode is the default. I even tried to use -sta in the command line (powershell -sta -file test.ps1 avo-vtl), but it didn't help.
Any chances to make it work?
Thank you.
Fri Jan 11, 2019 4:13 pm
powershell.exe -sta -file "path_to_your_script.ps1" - did you try it this way?
cforest
Fri Jan 11, 2019 4:42 pm
Boris (staff) wrote:powershell.exe -sta -file "path_to_your_script.ps1" - did you try it this way?
I did. It doesn't work, the same error.
Fri Jan 11, 2019 6:59 pm
Can you give me an example of how you ran it with STA enabled?
I would try saving this script on the remote server and do something like
Invoke-Command -Computername $tapeLibMachine -Credential $mycreds -ScriptBlock {powershell.exe -STA -file C:\myFolder\myScript.ps1}
cforest
Mon Jan 14, 2019 9:43 am
Boris, thank you so much, it works!
Honestly, running a script inside a script is a bit less convenient than specifying a code inside a script block, but I will be able to cope with that.
Mon Jan 14, 2019 9:52 am
Great!
P.S. I've moved (+shadow) thread to StarWind forum if you don't mind...
