alexfersh
Sun Jan 06, 2019 6:43 pm
Hello dear StarWind Team!
A lot of thanks for your wonderful product - StarWind VSAN!
I've been using it for Hyper-Converged POC in 2-node and 3-node design, and strongly consider buying the commercial version in the nearest future to use in the production environment.
Could you please clarify the following aspects:
1. In the latest StarWind VSAN builds - 8.0.12585 and 8.0.12658 - is it possible to configure L2 write-through cache with PowerShell scripts (VSAN Free license), and if it is, then how?
I've tried to do this according to the "Adding, Changing and removing L2 cache" guidance, but with no success. L1 RAM cache can be configured and works without issues though.
2. Is it possible and how to configure SW VSAN cluster in Node-Majority mode with a Witness node with PowerShell (VSAN Free license, builds 8.0.12585 and 8.0.12658)?
Looking forward for your kind reply.
Thank you very much in advance.
Alex Fershtein
alexfersh
Tue Jan 08, 2019 3:56 pm
Hello Boris,
Thank you for the answer.
In fact, I mean a regular L2 cache on SSD.
I've strictly followed recommendations as per the guidance you've mentioned, but haven't succeeded.
Anyway, this is a method of adding L2 cache with editing header files manually, not via Powershell.
Is there any possibility to accomplish the same then creating HA image device(s) with Powershell?
And what about creating VSAN HA devices with Node-Majority failover strategy and Witness node via Powershell?
A lot of thanks in advance.
Kind regards,
Alex Fershtein
Tue Jan 08, 2019 4:52 pm
You can configure L1 cache when creating HA devices via PowerShell, but not L2 cache.
I would just advise you to go through the guide once again and make sure you do everything as described. Also, make sure that IDs of the disks do not get duplicates. Each ID should be unique (L1 / L2 / actual data .img file).
umate
Tue Feb 12, 2019 8:58 pm
Hello Boris,
are there any plans for adding node majority to PS anytime soon? Heartbeat failover doesn't fail over automatically in my test when the SYNC network goes down first and the heartbeat network second.
Greetings,
Mate
Boris (staff) wrote:As for your second question, Node Majority is not available for configuration with PowerShell yet.
Tue Jun 09, 2020 2:04 pm
Please PM me your P.O. details and I might be able to escalate it. We're currently working on SMB3/NFSv3/v4 share as a witness, so we might consider covering this functionality alltogether.
gklpnd wrote:Have you any updates about node-majority strategy via ps?
CedricT
Tue Jun 30, 2020 11:05 am
Too bad
I think i found a tway to declare the failover mode :
$failover=0 => Heartbeat
$failover=1 => Node-Majority
The only piece missing is how to declare the witness now. May be as a $third.node without syncInterface but only hbinterface?
