can't login to esx server
wa4zlw
Fri Jan 04, 2019 9:25 pm
Trying to move from vmware back to Hyper-V and I downloaded the convertor and get this error attached capture
also, why can't the documentation be printed and is hard to find?
thanks leon
wa4zlw
Fri Jan 04, 2019 9:26 pm
Version:
6.7.0 (Build 8169922)
Oleg(staff)
Sat Jan 05, 2019 9:43 am
You can find the main steps you need with StarWind V2V Converter by following this link.
Thank you for the ticket, please check my suggestions.
wa4zlw
Sat Jan 05, 2019 1:23 pm
hi there...thanks for the prompt reply. but that link the document is not printable only get the first two pages, first is blank. Should have PDF documents.
The link you sent me via email doesnt work and I replied to it
thanks leon
Mon Jan 07, 2019 3:28 pm
The PDF doc is available at the bottom of that page. Here is the direct link: https://www.starwindsoftware.com/resour ... -Paper.pdf
