no add target availible
Gerards
Mon Dec 31, 2018 11:12 pm
i did a clean install on a M$ server 2016 standard, but i don't seem to be able on how to find the "add target"
When i rightclick the server (called NFS) which i reside on i would expect to appear a menu with add target and other thing, but the add target menu's don't appear
under configuration/advanced setting i do see |my computer\e\starwind, which is exactly the path i filled in when waling through the wizard.
A reboot didn 't resolve my issue
any idea's how i can setup my server to become an iscsi host?
Kind Regards
Gerard
Wed Jan 02, 2019 8:28 pm
As you use StarWind VSAN Free, all actions shall be done via PowerShell module called StarWindX, while GUI operates in the read-only mode.
You can find sample scripts in the StarWind installation folder.
