KeepInCloud, KeepInStorage
linchesterbr
Fri Dec 21, 2018 7:30 pm
Hello Users.
Someone can explain what means the following parameters and possible values for the VTLReplicationSettings.ps1 (PowerShell Script)?:
$settings.KeepInCloud=
$settings.KeepInStorage1=
$settings.KeepInStorage2=
Another thing. Should I create a Glacier Vault to move the files from S3 or do API this automatically? Beacause documentation says just about S3 bucket creation, but nothing about glacier.
Thanks in advance.
Oleg(staff)
Thu Jan 03, 2019 2:36 pm
$settings.KeepInCloud - The time for saving in the cloud, days. The data will be removed from the cloud after this time expiration (It is working for all the types).
The time for migration to different storage type.
For S3 only KeepInStorage1 parameter is working, it is the time of keeping on S3, after this time expiration the data is moving to Glacier
For Azure KeepInStorage1 that is the time of keeping data on Hot till the moment of moving to Cold, KeepInStorage2that is the time of keeping data on Cold till moving to Archive.
In the case of S3 you are making/changing the rule for the bucket, then Amazon is making everything by itself. The rule will work to all files in the bucket.
willn333
Tue Aug 06, 2019 3:13 am
Is there a setting in powershell for the option "Create new empty tapes automatically when existing tape removed from VTL for replication"?
Tue Aug 06, 2019 2:42 pm
Check this option on the example of Veeam B&R:
https://www.starwindsoftware.com/resour ... e418c70ca9
You need to the screenshot at step 9 of the Veeam block. Veeam has got that setting, which seems to be exactly what you are looking for.
willn333
Wed Aug 07, 2019 2:06 am
Boris (staff) wrote:Check this option on the example of Veeam B&R:
I don't think this is the same thing. Veeam wouldn't be able to just create a new tape in the VTL. That is done with the powershell commands:
$tapeType = [StarWindTapeType]::STARWIND_TAPE_ULTRIUM_LTO8
	$tape = Add-VirtualTape -VTLDevice $device -tapeType $tapeType -tapeSize $tapeSize -maxDataFileSize $maxDataFileSize
What I am trying to do is have a workflow of... backing up files to tape and eject them so they go to the offline shelf and get uploaded to the cloud. After a retention period of 30 days, reinsert the offline tapes into slots so that I can reuse them and remove the data from the cloud.
Is that possible?
Wed Aug 07, 2019 7:24 pm
The Veeam feature I outlined does work for numerous customers that have it configured in their environments, and I do not have any grounds for suspecting this functionality to be faulty (unless this is specific to your particular environment). Have you tried configuring this before stating that "Veeam wouldn't be able to just create a new tape in the VTL"? If so, something is definitely wrong there, as it has been working flawlessly for hundreds of others.
With Veeam, you also have an option of ejecting the tape after the backup is completed, so you can later query the VTL device to get the list of offline shelf tapes as we discussed in https://forums.starwindsoftware.com/vie ... 954#p29954 I believe other backup software may have that functionality as well.
willn333
Thu Aug 08, 2019 6:44 pm
Boris (staff) wrote:The Veeam feature I outlined does work for numerous customers that have it configured in their environments, and I do not have any grounds for suspecting this functionality to be faulty (unless this is specific to your particular environment). Have you tried configuring this before stating that "Veeam wouldn't be able to just create a new tape in the VTL"? If so, something is definitely wrong there, as it has been working flawlessly for hundreds of others.
Not sure if we are on the same page here. Bascially, I ran the Veeam job with no tapes in any slots but the ones that were in the offline shelf and I get a message from the Veeam job of "[Warning] Insert a tape to continue".
Veeam doesn't have the ability to create tapes in the VTL, nor does it have the ability to load a tape from the offline shelf. They are completely separate systems.
Any other ideas?
Mon Aug 12, 2019 7:54 am
We are on the same page, but in its different parts, if I may say so...
First of all, you will need a tape available for Veeam to write backups to. Once this backup is successful, the tape gets ejected (if the corresponding option is enabled in the backup job config) and here VTL tape creation kicks in (again - if it is configured to do so). If you do not have any tapes online, this will never work, no matter how long you would wait for this.
This does work for everyone using StarWind VTL and Veeam. I am sure this will do so for you, too, once you configure everything properly. Just post back any questions you have after you follow the guide on configuring Veeam B&R to be used with VTL that I posted last week.
willn333
Tue Aug 13, 2019 12:26 am
Boris (staff) wrote:We are on the same page, but in its different parts, if I may say so...
The reason this works is the setting in cloud replication on the StarWind side that I asked about in my previous post.
This setting to create a new tape when the existing one is ejected. You never answered if that setting is available via powershell. In looking at the sample scripts, it is not part of the settings properties and when I do a listing of all the settings for the CloudReplication Settings, it is only these:
Script:
Import-Module StarWindX
try
    $server.Connect()
	# common parameters
	$deviceName = "vtl1"
	$device = $null
	foreach($dev in $server.Devices)
		if( $dev.Name.Equals($deviceName) -and $dev.DeviceType.Equals("VTL") )
			$device = $dev
			break
	if( !$device )
		Write-Host "Device '$($deviceName)' not found" -foreground red
		return
	$device
	$settings = new-object -ComObject StarWindX.VTLReplicationSettings
	$settings
catch
    Write-Host $_ -foreground red
finally
	$server.Disconnect()
Output:
DeviceType             : VTL
DeviceId               : 0x0000004D8A100440
File                   :
TargetName             : iqn.2008-08.com.starwindsoftware:veeambackup-targetvtl1
TargetId               : 0x0000004D8A4DFA80
CacheMode              : empty
CacheSize              : empty
CacheBlockExpiryPeriod : empty
Exists                 : True
DeviceLUN              : 0
IsSnapshotsSupported   : False
Snapshots              :
SectorSize             :
State                  : 0
Tapes                  : System.__ComObject
AvailableSlots         : 96
TransportSlots         : 1
DriveSlots             : 4
ImportExportSlots      : 3
StorageSlots           : 96
Slots                  : System.__ComObject
ReplicationSettings    : System.__ComObject
DriveType              : 8
Target           : 0
AccessKey        :
SecretAccessKey  :
RegionName       :
ContainerName    :
KeepLocal        : -1
KeepInCloud      : -1
KeepInStorage1   : -1
KeepInStorage2   : -1
DelayBeforeStart : -1
ServiceUrl       :
As you can see, there is no setting in powershell for the "Create new empty tapes automatically when existing tape removed from VTL for replication."
Michael (staff)
Fri Aug 16, 2019 4:49 pm
Hello willn333,
The option "Create new empty tapes automatically when existing tape removed from VTL for replication." can be changed in VTL device configuration file. For example in my case it's located here: "E:\VTL\VTL.swdsk"
Just stop StarWind Virtual SAN and CloudReplicator services, open VTL.swdsk, locate the line "<createTapeOnExport>false</createTapeOnExport>", change "false" to "true", save file and start services back.
Let us know about the result.
dgbegfb
Tue Mar 31, 2020 11:31 am
Michael (staff) wrote:Hello willn333,
Hi Michael,
Thank you for the workaround, it really works as expected but there're two issues:
- each new tape creates with default maximum tape size and default part size.
- each time after VTLReplicationSettings.ps1 script execution the line "<createTapeOnExport>true</createTapeOnExport>" reverts to "false" state. It gives me a clue, may it can be set trough powershell script?
Is there any way to adjust such behaviour?
Tue Apr 07, 2020 8:06 am
Sorry for such a delayed response.
Happy to know it finally works!
That you can tune in the AddVirtualTape.ps1 script. See the lines to edit in the image below.
Well, these parameters cannot be modified in StarWindX yet.
I have created a feature request. Thanks for your effort to improve StarWind VTL!
image (10).png (5.67 KiB) Viewed 123198 times
dgbegfb
Tue Apr 07, 2020 8:47 am
Super, thanks. We're all in profit from such collaboration.
But such modification of AddVirtualTape script doesn't affect an automatic tape creation after the export.
Tue Apr 07, 2020 9:38 am
Sorry, got your question wrong. R&D guys are planning to modify the script so that tape that is created has identical properties as the offloaded one.
One more feature request I guess.
Thanks.
vondess
Sat May 16, 2020 4:38 pm
Thanks for all your responses. I have also found a response to my question here. I am from [ ... ], and I really like such forums. I have found a lot of technical information in similar threads. It is a good way to help each other. Sometimes an average user can share a lot of helpful tips. And it is great.
