StarWind V2V Converter - Login problem
GSivakolunthu
Tue Sep 04, 2018 4:40 pm
First I can't connect to ESXi server with port 443. Second if I uncheck port after connecting it is giving me blank screen. Can anyone explain why this is happening?
Attached Error
Gana
V2V Connection Error.PNG (34.13 KiB) Viewed 22087 times
Oleg(staff)
Wed Sep 05, 2018 12:47 pm
Could you please give more details. What version of ESXi are you trying to connect?
GSivakolunthu
Wed Sep 05, 2018 6:32 pm
ESXi 6.0
Oleg(staff)
Thu Sep 06, 2018 10:44 am
Are you trying to connect vCenter or the host itself?
Please connect to the ESXi host.
GSivakolunthu
Thu Sep 06, 2018 2:07 pm
I am connecting to host itself not to vCenter. Please let me know
Oleg(staff)
Fri Sep 07, 2018 8:07 am
Could you please clarify one more thing.
What version of StarWind V2V Converter are you using?
GSivakolunthu
Fri Sep 07, 2018 4:03 pm
How to find the version?
I downloaded from below link
https://www.starwindsoftware.com/tmplin ... verter.exe
Oleg(staff)
Tue Sep 11, 2018 7:28 am
Please check if you are connecting to the correct IP of ESXi host. Also please check if SSL is enabled on this host.
GSivakolunthu
Wed Sep 12, 2018 7:52 pm
I connect to correct host/IP with right credentials with SSL. Still have problem. I am not getting any solution
Oleg(staff)
Fri Sep 14, 2018 4:29 pm
Could you please log a support case using this form.
