Run StarWindX Powershell Scripts Remotely
xpystchrisx
Mon Jul 30, 2018 5:43 pm
I'm setting up some remote monitoring for our VSAN Free cluster, basically I just want to keep an eye on the status of disks and starwind it self.
I've hacked together a few powershell scripts using the examples provided etc. However the system that I'm using to run the scripts and collect the status, PRTG, runs the script from a remote "probe" which needs to have the StarWindX module installed on it. Is there any way to get that module installed on the remote system?
xpystchrisx
Mon Jul 30, 2018 7:31 pm
I figured it out. The installer includes the option to just install the Powershell extensions.
Mon Jul 30, 2018 9:29 pm
Correct, when running the StarWind VSAN installer you can select only StarWindX PowerShell module for installation by keeping it checked and unchecking any other option.
