One node lost disk path from imagefile
churos
Mon Jul 16, 2018 7:08 am
I use VSAN Free in two node solutions.
After one outage, I found that all nodes were not synchronizing all the disks.
In recovery, I worked on the node1 to mark the discs as synchronized to run the MS cluster.
I check the second node, and according to the date on the disk I find that img files have an old time.
And from the powershell I find this:
HAImage3 0x000001D4CA3F9440 My Computer\E\SAS\SAS_HA.swdsk iqn.2008-08.com.starwindsoftware:172.27.0.2-sas 0x000001D4CA3B5F80 empty wb 128 5000 True False
HAImage2 HA Image 0x000001D4CA3AB7C0 My Computer\D\SATA\SATA_HA.swdsk iqn.2008-08.com.starwindsoftware:172.27.0.2-sata 0x000001D4CA439F80 966367641600 wb 128 5000 True 0 False
HAImage4 0x000001D4CA4394C0 My Computer\E\Witness\Witness_HA.swdsk iqn.2008-08.com.starwindsoftware:hv2.novyrychnov.local-witness 0x000001D4D27DD500 empty wb 128 5000 True False
imagefile1 0x000001D4CA40D440 empty empty empty empty empty empty True False
imagefile3 0x000001D4CA43ECC0 empty empty empty empty empty empty True False
imagefile2 Image file 0x000001D4CA37AEC0 My Computer\D\SATA\SATA.img empty
In two disk missing img paths.
In node1 it is all OK.
How can I recover configuration with powershell? Any log exist with old cfg?
Oleg(staff)
Fri Jul 20, 2018 1:55 pm
What StarWind build are you using?
Can you please collect the logs from your servers and share with us for better understanding the problem you faced?
You can collect log using this tool.
