Install OS errors
min4er
Thu Mar 22, 2018 5:42 pm
Hello!
I connect to StarWind free ISCSI device via iPXE, and try to install win 7or 10. It seems installation is complete, but after that I can not load system. Loading starts, but fails because of errors in files (can not verify signature or can not find file). Is there a way to add missing files to ISCSI disk (edit image?) And what may be the reason of errors? Bad OS distributive or what else? Installation works slow, and I missed 2 days yet...
Sat Mar 24, 2018 2:46 pm
What on-line or our own guide did you use to iSCSI boot your Windows 7 or Windows 10 boxes?
min4er wrote:Hello!
min4er
Thu Mar 29, 2018 5:26 pm
Thank you, I solved my problems. But, what about editing images? Is there a way to open/convert/mount one?
Oleg(staff)
Mon Apr 02, 2018 1:52 pm
You can try to connect the device with the help of the ISCSI initiator and then make changes you need.
You can convert device in StarWind V2V Converter to the necessary format.
