Internal error (9) [0] while converting .vhd to .vmdk
bizzypumping
Sun Jan 21, 2018 2:20 pm
Please am trying to convert hyper -V .vhd to vmdk but getting the error Internal error (9) [0] while converting .vhd to .vmdk
Kindly help.
Mon Jan 22, 2018 10:16 am
bizzypumping,
I need several questions answered to troubleshoot this issue:
1. What is the VMDK format that you use as your target?
2. What is the type of the VHD disk you are converting?
3. Are Additional Options active in your case?
4. Is the disk that is being converted used by another program/process at the time of conversion?
5. Is there any particular reason for converting a local disk using network shares?
bizzypumping
Mon Jan 22, 2018 11:34 am
Boris,
Please find answers requested below
1. What is the VMDK format that you use as your target? -----vmware
2. What is the type of the VHD disk you are converting? ---- hyper-V vhd
3. Are Additional Options active in your case? ---no
4. Is the disk that is being converted used by another program/process at the time of conversion? ----No its a microsoft training lab that am trying to setup
5. Is there any particular reason for converting a local disk using network shares? ----I dont understand this question please
Thanks for your help
Mon Jan 22, 2018 3:48 pm
Any further info? Like whether it is Eager Zeroed/Lazy Zeroed/Thin Provisioned
Any details? Thin or Thick provisioned?
Have you tried converting the same file with the path like "E:\Administering...." instead of "\\localhost\E$\Administering..."?
