luzai
Wed Dec 20, 2017 5:49 am
IMG file convert to VMware ESXI server image,ESXI warn disk size which is larger than its original capacity.
The correct disk size should be 272M.
https://downloads.lede-project.org/rele ... uashfs.img
- QQ截图20171222175724.jpg (124.25 KiB) Viewed 10432 times
- QQ截图20171220134302.jpg (63.28 KiB) Viewed 10445 times
luzai on Fri Dec 22, 2017 10:19 am, edited 3 times in total.
Thu Dec 21, 2017 5:55 pm
The linked file is 18.9MB when downloaded, and it cannot be converted to 272MB for obvious reasons. Just make sure you use the correct file.
