vSan performance counters
wi3dzma
Fri Oct 20, 2017 3:52 pm
are there any performance counters or other tools by which we can monitor performance of Starwind vSan?
Especially L1 Cache Usage or Synchronization statistics.
Best Regards,
Malwina Leis
Sat Oct 21, 2017 12:18 pm
Malwina,
L1 cache usage can be monitored directly from the StarWind Management Console. Check this out:
wi3dzma
Tue Oct 24, 2017 12:15 pm
Boris,
thank you for the answer, but I was looking for something that can be used for gathering statistics and sending them to influx, ie. can be queried using powershell, wmi or other command line tool. Is there anything like that?
Best Regards,
Malwina
Tue Oct 24, 2017 1:31 pm
Malwina,
At the moment it is not possible to get those metrics automatically. Yet, in future releases of StarWindX this feature will be added.
