According to KB article, StarWind will do a full synchronization if both StarWind services were stopped. By design, StarWind services will identify what devices have the most recent data and will start full synchronization in a correct way.1) node 1 shutted down gracefully; after 5 minutes, even node 2 is shutted off gracefully; after 5 minutes, both nodes are switched on again (almost in the same time)
2) node 1 and 2 shuts down gracefully but more or less in the same time; after 5 minutes, both nodes are switched on again (almost in the same time)
In this case, both devices could stay not synchronized after nodes back up. In order to resolve this situaltion, device with the most recent data should be marked as Synchronized manually. This KB article should be helpful for such case: https://knowledgebase.starwindsoftware. ... -blackout/3) node 1 and 2 do an unexpected power off (e.g. power outage without UPS or UPS running out of batteries); once power is back, both nodes are switched on again (almost in the same time)
Hello, I found this discussion very interesting. But I have a question that crosses my mind with the last answer. how does one manage to execute for an HA command in powershell 'MArk as Synchronized'?Michael (staff) wrote:Hello Tiaccadi,
Please find here a link when full synchronization can occur: https://knowledgebase.starwindsoftware. ... may-start/
Answering your questions - if you gracefully shutdown one of the nodes, StarWind will do a fast synchronization when it will back up.According to KB article, StarWind will do a full synchronization if both StarWind services were stopped. By design, StarWind services will identify what devices have the most recent data and will start full synchronization in a correct way.1) node 1 shutted down gracefully; after 5 minutes, even node 2 is shutted off gracefully; after 5 minutes, both nodes are switched on again (almost in the same time)
2) node 1 and 2 shuts down gracefully but more or less in the same time; after 5 minutes, both nodes are switched on again (almost in the same time)In this case, both devices could stay not synchronized after nodes back up. In order to resolve this situaltion, device with the most recent data should be marked as Synchronized manually. This KB article should be helpful for such case: https://knowledgebase.starwindsoftware. ... -blackout/3) node 1 and 2 do an unexpected power off (e.g. power outage without UPS or UPS running out of batteries); once power is back, both nodes are switched on again (almost in the same time)
Additionally, next StarWind build will have Maintenance mode for HA devices, thus you can put devices in the Maintenence mode, shutdown/turn off both servers and after servers back up and leaving Maintenance mode, StarWind will do a fast synchronization. It will come very soon!
