Starwind Virtual SAN V8 refuses to install on Windows Server 2016
xomagen
Sat Jun 10, 2017 10:37 pm
Forgive me if this has been asked, but I cannot get Virtual SAN v8 to install on my server 2016 machine. It keeps failing with the message "Setup failed to install Microsoft .NET Core. Error 3010. Is there a solution for this?
Ivan (staff)
Mon Jun 12, 2017 2:05 pm
Hello xomagen,
Thanks for your interesting in StarWind solution.
You can try 3 possible workarounds:
1) Install .NET Core before StarWind. Download and install SDK and runtime (version 1.1.2) from Microsoft by following next link: https://www.microsoft.com/net/download/core#/sdk (Note: system reboot require)
2) Reboot your servers and try to install StarWind one more time
3) Uncheck "Cloud Replicator for VTL" in StarWind Virtual SAN Wizard
Ironwolf
Fri Jun 16, 2017 1:55 am
Had a similar error on a 2012 system, error 12029, .NET Core
I resolved it by installing .NET Core x64 1st and then installed Starwind
Ivan (staff)
Fri Jun 16, 2017 7:38 pm
Hello Ironwolf,
Thanks for your interest in StarWind solution.
Thanks for the information!
tig_jeff
Fri Jun 23, 2017 6:14 pm
I'm having a very similar issue. However I'm getting error 0x80070490.
It tries to install Visual C redistribute... but fails.
I have installed this manually... but it still fails.
It directs me to a "log file" but I cannot find where that may me.
I've attached a screen shot.
Also...
This server IS NOT connected to the internet.
All files are FTP'd to the system.
Any help would be great... like a list of prerequisites.
11156 Error on .Net Core / VC install
Hope this helps.
- Jeff Morlen
Follow me on Twitter (@tig_jeff)
Ivan (staff)
Thu Jun 29, 2017 1:46 pm
Hello tig_jeff,
Could you share with us log file?
Also, you can try to install VC_redist.x64.exe. You can download from: http://go.microsoft.com/fwlink/?LinkID=615460
