starwind Gateway
trini18
Thu Jun 08, 2017 4:23 pm
ive downloaded the appliance and installed in in Hyper-V no where in the document says what the username and password is so I can login and change ip address
does anyone know what the default is?
thanks
trini18
Thu Jun 08, 2017 5:18 pm
just so you know what am talking about
https://www.starwindsoftware.com/starwi ... tion-guide
Ivan (staff)
Fri Jun 09, 2017 8:23 pm
Hello trini18,
Thanks for your interest in StarWind solution
You can't login inside CentOS VM, it is locked to log in.
For StarWind Web console use the following credentials:
Username: starwind
Password: starwind
By default, Gateway virtual machine will recieve automatic IP address via DHCP. It is recommended to create a DHCP reservation, configure DNS resolving and set a static IP address for this VM. In order to access StarWind Web Console outside from your local network, Gateway virtual machine must have Internet access.
trini18
Tue Sep 12, 2017 7:59 pm
what if its not possible to use dhcp?
trini18
Tue Sep 12, 2017 8:56 pm
trying to add a new connection and its telling me Connection names must not be blank.
not sure were to fill that
Sergey (staff)
Wed Sep 13, 2017 4:34 pm
Hello, Trini18. Are you sure you are using correct IP for connection? Can you ping the Gateway VM?
trini18
Wed Sep 13, 2017 4:51 pm
am logged into it webgui
and am trying to add a new connection
when I click save a pop box comes up
its telling me
Error Connection names must not be blank.
Sergey (staff)
Thu Sep 14, 2017 4:38 pm
Please, note, you have to have an active (purchased or trial or free within 30 days period after activation date) license with unlocked GUI in order to use web (thin) client for StarWind Management Console.
trini18
Thu Sep 14, 2017 5:54 pm
I do have an active lic
trini18
Thu Sep 14, 2017 5:55 pm
I built a new server and just installed web components with webgui...did not want to install it on storages
Sergey (staff)
Fri Sep 15, 2017 3:18 pm
StarWind Web Console is for management existing StarWind disks. You have to Install StarWind Web Console feature using StarWind Virtual SAN Installer Wizard. You can
install that on your Windows-based physical host or virtual machine that has LAN access to your StarWind Virtual SAN servers.
