I confirm that this VSA version is working on lab based on Intel Xeon E5420, thanks for your work!
I take this opportunity to ask if I missing something during storage configuration on VSA for vSphere (i used the "StarWind Virtual SAN® for vSphere Installation and Configuration guide"):
- Added vDisk of 60GB to VSA
- Login to appliance through web portal and format the new disk (Attachment 1)
- 1.jpeg (248.48 KiB) Viewed 15066 times
- Open Management Console and connect to VSA, the message that appears is different than the one reported in the guide
- 2.jpeg (76.42 KiB) Viewed 15066 times
I have tried with different file system types, different mount points but without luck. Management console version is 8.0.0.12585.
I also noticed that under configuration i don't have the options "VSA Storage" and "VSA Network" (as appear in
https://www.starwindsoftware.com/techni ... yper-V.pdf)
- 3.jpeg (89.68 KiB) Viewed 15065 times
Do you have any suggestion?
Thanks in advance
