Error in Powershell script for creating HA device 2 nodes
Alpanet
Fri Apr 07, 2017 5:12 pm
Hi to everybody,
when I tried to use the sample script to create a 2 nodes HaDevice I recieved this error:
"Plugin does not support."
Anybody can help me please?
Thaks a lot
Andrea
Import-Module StarWindX
try
$server = New-SWServer -host 192.168.1.10 -port 3261 -user root -password starwind
$server.Connect()
$firstNode = new-Object Node
$firstNode.ImagePath = "Host1\C\StarWindHA"
$firstNode.ImageName = "Csv1"
$firstNode.Size = 100000
$firstNode.TargetAlias = "targetha1"
$firstNode.AutoSynch = $true
$firstNode.SyncInterface = "#p2=172.16.20.10:3260"
$firstNode.HBInterface = "#p2=172.16.10.10:32600"
$firstNode.CacheSize = 640
$firstNode.CacheMode = "wb"
$firstNode.PoolName = "pool1"
$firstNode.SectorSize = 512
# 'SerialID' should be between 16 and 31 symbols. If it not specified StarWind Service will generate it.
# Note: Second node always has the same serial ID. You do not need to specify it for second node
$firstNode.SerialID = "050176c0b535403ba3ce02102e33eab"
$secondNode = new-Object Node
$secondNode.HostName = "192.168.1.12"
$secondNode.HostPort = "3261"
$secondNode.Login = "root"
$secondNode.ImagePath = "Host2\C\StarWindHA"
$secondNode.ImageName = "partnercsv1"
$secondNode.Size = 100000
$secondNode.TargetAlias = "targetha2"
$secondNode.AutoSynch = $true
$secondNode.SyncInterface = "172.16.20.11:3260"
$secondNode.HBInterface = "#p2=172.16.10.11:32600"
$syncState = $device.GetPropertyValue("ha_synch_status")
while ($syncState -ne "1")
# Refresh device info
$device.Refresh()
Start-Sleep -m 2000
catch
Write-Host "Exception $($_.Exception.Message)" -foreground red
$server.Disconnect()
Ivan (staff)
Tue Apr 11, 2017 2:18 pm
Hello Alpanet,
Thanks for interesting in StarWind solution.
As far as I can see in your script you typed the wrong Image path:
Should be:
$firstNode.ImagePath = "My Computer\C\StarWindHA"
Or:
$firstNode.ImagePath = "C:\StarWindHA"
Please, make this changes in example script and try one more time.
Keep us updated about it.
Alpanet
Mon Apr 24, 2017 9:55 am
Hi Ivan,
sorry for the late answer but I just tried your advice but the result seems the same:
PS C:\Users\adm> C:\Users\adm\Documents\CreateHA2nodes.ps1
Exception Plugin does not support.
Can you help me?
Thank a lot
Andrea
Powershell script is below:
try
$server.Connect()
$secondNode.HostName = "192.168.1.11"
$secondNode.ImagePath = "C:\StarWindHA"
$device.Refresh()
Start-Sleep -m 2000
catch
Ivan (staff)
Tue Apr 25, 2017 6:27 pm
Hello Alpanet,
Try this one:
create the folder on C: drive. Without ##IP FROM SECOND NODE and ##IP FROM FIRST NODE
Also, make sure you have enough space for this device
try
$server.Connect()
$firstNode.ImagePath = "My computer\C\StarWindHA"
$firstNode.SyncInterface = "#p2=172.16.20.10:3260" ##IP FROM SECOND NODE
$firstNode.HBInterface = "#p2=172.16.10.10:32600"  ##IP FROM SECOND NODE
$secondNode.ImagePath = "My computer\C\StarWindHA"
$secondNode.SyncInterface = "p1=172.16.20.11:3260" ##IP FROM FIRST NODE
$secondNode.HBInterface = "#p1=172.16.10.11:32600" ##IP FROM FIRST NODE
$device.Refresh()
Start-Sleep -m 2000
catch
Alpanet
Tue May 16, 2017 10:57 am
Hi Ivan,
sorry but I had an accident and I returned in office only yesterday... :|
Thanks for your reply but i don't understand what you mean when you said:
"create the folder on C: drive." : the folder is already created on both hosts
and when you said:
"Without ##IP FROM SECOND NODE and ##IP FROM FIRST NODE" I dont understand which part of code I have to remove...
Sorry but I am new with this technologies... :-)
Thanks a lot for your support
Andrea
Ivan (staff)
Tue May 16, 2017 2:50 pm
Hello Alpanet,
I mean delete ##IP FROM FIRST NODE from my example.
Try to run this one:
#Import-Module StarWindX
try
    $server.Connect()
    $firstNode.ImageName = "masterImg1"
    $firstNode.TargetAlias = "csv1"
    $firstNode.SyncInterface = "#p2=172.16.20.11:3260"
    $firstNode.HBInterface = "#p2=172.16.10.11:3260"
    $secondNode.ImageName = "partnerImg1"
    $secondNode.TargetAlias = "csv1"
    $secondNode.SyncInterface = "#p1=172.16.20.10:3260"
    $secondNode.HBInterface = "#p1=172.16.10.10:3260"
        $device.Refresh()
        Start-Sleep -m 2000
catch
Alpanet
Wed May 17, 2017 5:58 pm
Hi Ivan,
I tried this but the result is the same:
"Exception Plugin does not support."
I launched this script from a Win10 pc Powershell ISE in the same subnet 192.168.1.0
What I got wrong?
Thanks a lot for your patience
Andrea
try
$server.Connect()
$firstNode.HBInterface = "#p2=172.16.10.10:3260"
$secondNode.SyncInterface = "#p1=172.16.20.11:3260"
$secondNode.HBInterface = "#p1=172.16.10.11:3260"
$device.Refresh()
Start-Sleep -m 2000
catch
Ivan (staff)
Wed May 17, 2017 10:47 pm
Hello Alpanet,
To do it properly you need to install StarWind vSAN on your desktop PC (I suppose) and change 127.0.0.1 to the management IP from first host (which will be primary).
Try to run this script directly on Host which will be used to vSAN.
Also, I would recommend to update StarWind vSAN to the latest build, which you can find by following next link:
https://www.starwindsoftware.com/regist ... irtual-san
