I am trying to setup a 2 node cluster with the free license in order to try this with hyper-v failover.
Unfortunately this appears to be trickier than i though and always fails with "Invalid Partner Info"
I have 2 servers with 2 NICs, one connected to the 10.1.2.0 network to the DC and one connected to 192.168.1.0 on each server respectively.
I am able to create a new device but unable to sync. The device wizard looks different than in any of the tutorials I found online
- I am not able to select a file name/path for the virtual disk file
- also there seems to be no option to define a L2 cache
Once I created a device and attempt to add a replication partner I need to select an interface for heartbeat and syncing
- bot NICs are grayed out by default and I need to check the box in the bottom in order to select each interface for sync and the other one for heartbeat
- at the last step when creating the replication process it eventually errors out with the "Invalid Partner Info". I understand this is a common error but I could not find any specific pointers for this error.
I did reinstall stawind a couple times but that did not help unfortunately
I tried to follow online tutorials but the interface always looks slightly different and i am afraid I missed something significant in my setup. Could someone help point me in the right direction?
Thx
Nilzor
