IQN Name Change
jhonken
Tue Sep 13, 2016 1:49 am
Is it possible to change the target IQN Name once its been generated?
Michael (staff)
Thu Sep 15, 2016 6:58 pm
Hello jhonken,
It is impossible to change the target IQN Name once it was created.
Alternatively, you can follow the steps below:
-turn off Production on existing target and disconnect it from iSCSI Initiator;
-remove device under existing target;
-add device back as Existing Virtual Disk and Choose the Targert Attachment Method as Unassigned. Use Add Device (advanced) wizard to complete it. It will be added without target;
-add the new target with the correct name;
-right click on the newly created target and Add existing Device to Target from appeared list;
-connect new target in iSCSI initiator and turn on Production.
